#1 |
I have just bought some Havoline 20-W50 oil for my Model A. I bought it because it says "better wear protection for older engines". But then I noticed it also says API SJ. I recall reading somewhere that it should be API SC for Model As? I know some guys think its not important but I want to get it right if possible.
#2 |
Good Evening...Model A Engines should have SN engine oil according to a recent article in Model A Times...Give it a read and then decide...Ernie in Arizona
#3 |
The 20-W50 oil will work just fine in your Model A. This is way better stuff than what was available when your Model A was new.
Chris W. |
#4 | |
![]() Quote:
SJ is more than good for an A. SC oil will be hard to find and expensive if you do.
#5 |
#6 |
Jim |
#7 |
![]() The cheap oil at Walmart is SN.
#8 |
Rotella T and don't worry about the little stuff.
#9 |
Zinc is not needed after break in on the A motor, zinc was added later due to higher engine speeds requiring stiffer valve springs to prevent valve float.
#10 |
What Rotella do you use? T4?
#11 | |
![]() Quote:
#12 |
If you do a search, tons of discussion on this. I consider this a good thread.
https://www.fordbarn.com/forum/showthread.php?t=159816 Too much Zinc is bad, more is not better. I use Rotella T4, has some zinc, might help, but should do no harm unless too much zinc is added. I personally do not believe Zinc is required in the Model A motor.. Opinions vary. |
#13 |
![]() Rotella is the little stuff.
