Old 02-16-2020, 12:16 PM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default The Diamond Mark Challenge
Where did this myth about the "Diamond" marked engines and parts being superior to factory items come from. I think the diamond is a pattern maker's and or foundry trademark having nothing to do with the attributes of items bearing the "Diamond."
By the way, I have 2 Model "B" engines and some Model "A" parts with the infamous "Diamond" mark. I do not see any quality, functional or ruggedness differences in comparison to their original factory parts.
I challenge anyone to show me facts / physical evidence / era literature that substantiates the "Diamond" mark has any worthwhile significance.
Bob Bidonde
Old 02-16-2020, 03:21 PM   #2
Synchro909
Synchro909's Avatar
Default Re: The Diamond Mark Challenge
I'm all ears too.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 02-16-2020, 03:43 PM   #3
Kurt in NJ
Kurt in NJ's Avatar
what i see is a original A block has a X reinforcement under the stud in the center, diamond blocks have none ---most diamond blocks have exhaust seat inserts
Old 02-16-2020, 04:19 PM   #4
ursus
I have yet to come across a diamond "A" block but have been through a number of diamond "B" blocks that were beyond restoration because of casting flaws, mainly core shifts that resulted in thin walls in the upper deck, valve pockets, and the roof of the valve chamber. Cracks running everywhere. Try to pin a crack and new ones form at the periphery. The original Ford produced "B" blocks have their issues as well. Since most all of my "B" engines spent their lives in an industrial application it is possible that they were not always well maintained. All told, I found one repairable diamond "B" block out of 7 that were hot-tanked and magnefluxed - not a good record.
As far as the diamond "B" blocks are concerned, my take is that their claimed superiority is a myth.
ursus is offline   Reply With Quote
Old 02-16-2020, 04:36 PM   #5
jw hash
jw hash's Avatar
I have had three diamond A blocks, two came out of tugs that I had bought, that were used on the water front. none of the three had exhaust seat inserts.
jw hash is offline   Reply With Quote
Old 02-16-2020, 04:55 PM   #6
jetmek
I believe the diamond is just a casting artifact seen on mid 30’s produced parts. It shows up on v8 parts as well. No special significance
engine and component overhauls my specialty!
Website- www.godevilgarage.com
jetmek is offline   Reply With Quote
Old 02-17-2020, 07:21 AM   #7
springerpete
springerpete's Avatar
Vince Falter has quite a bit of information on diamond blocks on his Ford Garage site. Check it out. I have a diamond block in my '29, certainly a replacement as the casting date is either '35 or '37. ( away from home now and can't check ) Runs just fine and has for years. Bill
springerpete is offline   Reply With Quote
Old 02-17-2020, 12:02 PM   #8
Jim Brierley
The diamond is a foundry mark, most, if not all were made after regular production, up to the war years. All were not the same, I have one diamond B block that was extremely thin in #3 exhaust port, another was ported to 1 3/4" and was still serviceable. The mark was A & B blocks, heads bell housings and on rear bearing (transmission) retainers and probably more??? They came with no serial number from the factory, most were used commercially. Were they better? They were newer, and most had exhaust seat inserts.
Jim Brierley is offline   Reply With Quote
Old 02-17-2020, 03:15 PM   #9
TerryH
TerryH's Avatar
My 1930 Town Sedan has a diamond block, but have no idea if it was original. It also has standard valve seats.....
TerryH is offline   Reply With Quote
Old 02-17-2020, 05:24 PM   #10
Fullraceflathead
Fullraceflathead's Avatar
I have a Model A Diamond Block and head.casting date is very hard to read but looks like 37
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 02-18-2020, 11:58 AM   #11
Joe K
Joe K's Avatar
I think for a while everyone thought that a diamond mark somehow affirmed "better quality?"
Now perhaps not so? I have seen diamond blocks sell for premium over a regular block. Well, I have seen diamond blocks ASK a premium.
I'm not sure I would bother. IMHO, the most "bulletproof" blocks seem to be motherhood & apple pie "A" blocks from the original production. My B "Gordon Smith" compressor (no counterweights) suffers from deck cracks on cylinders 2 and 3 - and this seems common for B - although the block may have been chosen for the GS Head BECAUSE it developed cracks.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 02-18-2020, 02:30 PM   #12
rotorwrench
rotorwrench's Avatar
Ford farmed out almost all replacement casting stuff after normal production of parts ended. Model A & B blocks were used in industrial & agricultural related applications long after the automobiles that used them had stopped production. I've only seen foundry marks on replacement transmission cases but not on engine block castings other then the diamond. Those that I have seen had the distinctive marking of Fairmount Tool and Forging Division of Houdaille Industries of Cleveland, OH but there were likely others too. Ford Motor Company seldom ever counted on any one supplier.
Old 02-18-2020, 03:08 PM   #13
Dan Partain
Dan Partain's Avatar
I have a diamond block with the exhaust seats. I don't know if all diamond blocks had them. It may be difficult to see them unless you have the block decked.
Dan Partain is offline   Reply With Quote
Old 02-18-2020, 07:01 PM   #14
rotorwrench
Not all had them.
Old 02-18-2020, 08:39 PM   #15
garyjohn
I think the diamond was put on all motors, A and B that where Industrial motors not to be put in autos but work horses. I could be wrong but I think I read that somewhere
garyjohn is offline   Reply With Quote
Old 02-18-2020, 09:14 PM   #16
DBrer
I wasn't aware that there was any difference.
DBrer is offline   Reply With Quote
Old 02-19-2020, 09:37 AM   #17
rotorwrench
There were two foundries in Cleveland Ohio that used a diamond casting mark. I always wondered if either of them were involved with these blocks. There is blind theory and then there is consensus among experienced folks in the restoration hobby. After 1933, Ford was busy casting V8 blocks so it's doubtful that they wanted to cast more 4-cylinder blocks if they didn't have to. Ford Motor Company certainly built up 4-cylinder engines through the 30s & early 40s for replacements and industrial/agricultural customers but that doesn't mean that they fabricated all the parts in house. Low production fabrication was farmed out a lot.
Old 02-23-2020, 10:11 AM   #18
Bob Bidonde
So far, I see no factory documentation or aftermarket testing that substantiates that "Diamond" blocks and parts are more rugged and or function better than OEM parts.
Thus in the market place, the "Diamond" should not add any $$ value to blocks and or parts with the "Diamond."
Bob Bidonde
Old 02-23-2020, 12:18 PM   #19
johnneilson
Bob,
You are probably correct about the value perceived of the Diamond castings.
But, someone could perceive that the Diamond block is more valuable just due to the age of the casting from the 40's, vs the 20's.
IMHO, a good block isn't just based on the date of manufacture, rather it is the condition and not having some questionable machining performed on it.
John
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
