Old 02-17-2020, 03:54 PM   #1
BUBBAS IGNITION
BUBBAS IGNITION's Avatar
Default Dont do this !!!
Dont do this !! I warranty and adjust any dist we build for life , you just put it in a box with 25 bucks , i will adjust and return to you.........
This is one of those that should be a esy fix we built this unit 3-4 years ago and customer ( for some reason) just removed it from engine and installed new contact points , ran for a while but was intermittant etc.
Installed on machine distributor would only fire part time !! Noticed timing tab was all the way up ( way too far) causing internal coil spring to loose contact from time to time . Contact point wont adjust to spec seems as if rubbing block is worn out and very dry !!!!!
Moral is :
Dont think the timing tab will bail you out of a problem ( this aint a chevy V8) Its only 6 deg up and 6 degrees down ....Hard to tell 6 degrees on a flathead performance wise ..........Advance causes spring to not connect good
Install new points with a good lube , fiber blocks wear quick..
Thia unit will require new points and lube to run right .....
If it Makes Spark, we do it !!!!
www.bubbasignition.com
[email protected]
BUBBAS IGNITION is offline   Reply With Quote
Old 02-18-2020, 11:51 AM   #2
grumppyoldman
grumppyoldman's Avatar
Default Re: Dont do this !!!
Thanks for the heads up.. Mine you rebuilt is running fine. Al
grumppyoldman is offline   Reply With Quote
Old 02-18-2020, 12:40 PM   #3
19Fordy
19Fordy's Avatar
Amazing that someone would think moving the timing mark would cure the problem.
Thank goodness he has you for a teacher.
Old 02-18-2020, 08:22 PM   #4
Tinker
Tinker's Avatar
I always thought that was the point of sending you a distributor. I don't have to mess with it.. at least for a couple yrs when I get bored.
Old 02-19-2020, 04:57 AM   #5
BUBBAS IGNITION
Originally Posted by tinker View Post
i always thought that was the point of sending you a distributor. I don't have to mess with it.. At least for a couple yrs when i get bored.
amen !!!
[email protected]
Old 02-19-2020, 09:33 PM   #6
TagMan
With all due respect, if you're retiring and no one is carrying on your business, the lifetime warranty is over, isn't it?
TagMan is offline   Reply With Quote
Old 02-21-2020, 10:18 AM   #7
BUBBAS IGNITION
Not really i will ( and can i hope) still walk to the shop and adjust a distributor etc. I have had very little warranty over the years we have figured out what goes wrong and made a patch for that problem......
The other issue is that most dont drive many miles on their cars ........
Just a few years ago we shipped 450 distributors in a year ! Thats the part i am stepping away from ! Last year Terry, Jake and I ( just the three of us ) shipped 180 units , cant do the mass anymore ...
[email protected]
Old 02-22-2020, 08:36 AM   #8
D. Jones
D. Jones's Avatar
I would be nice if your grandson was interested in stepping up and carrying on your business, with your guidance of course.
Hope you get your health issues resolved.
D. Jones is offline   Reply With Quote
