Old 01-10-2021, 11:11 AM   #1
3twinridges
3twinridges's Avatar
Default 52 F1 cluster gear
I have been working on building a 52 F1 3 speed remote shift transmission. Mostly all NOS parts including the case. I have built several before, but this time I am paying more attention to part fitment. I am using a NOS 27-23-17-13 cluster with needle bearings. I noticed the spacer isn’t a precise fit in the cluster bore. It’s not extremely loose, but not a tight fit either. I wonder why the spacer was designed that way? Seems like it’s an opportunity for transmission noise when the cluster rotates?
JB
File Type: jpg FB58DC39-819A-4CE1-8FDE-F1955997B3D6.jpg (57.0 KB, 10 views)
3twinridges is offline   Reply With Quote
Old 01-10-2021, 01:48 PM   #2
alanwoodieman
Default Re: 52 F1 cluster gear
diameter? probably some inexpensive off the shelf tubing, noise it should be drowned in trans fluid and thus no noise
alanwoodieman is offline   Reply With Quote
Old 01-10-2021, 02:15 PM   #3
KiWinUS
KiWinUS's Avatar
It is located by the shaft. Doesn’t matter how much it floats in cluster before shaft is installed.
Thread Tools
Display Modes
