12-24-2020, 02:40 AM | #1 |
voltage control for gauges
just a quick question runtz type voltage drops how many king sealy gauges will one run successfully
12-24-2020, 07:48 AM | #2 |
Re: voltage control for gauges
Not sure on this, but each seem to be made for a single guage only.
What do you have in mind? |
12-24-2020, 09:09 AM | #3 |
The instructions are very clear only one per gauge.
Sent from my iPad using Tapatalk |
12-24-2020, 11:14 AM | #4 |
If you are converting from 6 to 12 V use a CVR. Use a Ron Francis CVR (constant Voltage reducer) for best results. Read this:
https://www.fordbarn.com/forum/showt...oltage+reducer Do a search on Constant Voltage Reducer and tons of info. appears. Last edited by 19Fordy; 12-24-2020 at 11:21 AM. |
12-24-2020, 12:55 PM | #5 |
Use what Ford used, starting in '57. NAPA # IR1.
12-24-2020, 01:23 PM | #6 |
12-25-2020, 06:17 AM | #7 |
thanks one per gauge need to get gauges working correctly on 39 mercury
