Old 12-22-2020, 08:13 AM   #1
Joop
Joop's Avatar
Default Floorboard drawing for 1931 Ford with 1939 Transmission
Can someone post some pictures/drawings and measurements on the modified
floorboard they made for the 1939 transmission tower in there 1931 Model A.
Thanks
Joop is offline   Reply With Quote
Old 12-22-2020, 12:03 PM   #2
Russ B
Default Re: Floorboard drawing for 1931 Ford with 1939 Transmission
Make your own pattern in cardboard, test it, and then make one in plywood after you get the pattern right. Pretty simple job.
Russ B is offline   Reply With Quote
Old 12-22-2020, 12:24 PM   #3
Joop
Joop's Avatar
Thanks Russ
I know it is simple but like to see what people did do to it the right way.
As I bought the floorboard that has the big battery opening to remove it.
Merry Christmas
Old 12-24-2020, 12:42 PM   #4
Joop
Joop's Avatar
Help!
Old 12-24-2020, 01:02 PM   #5
Russ/40
Russ/40's Avatar
Hoop, I have a 39 tranny in my 29RPU. I can send you photos by weeks end, as well as a template for the steel plate. I also made my own mat which may interest you.
Stand by.....
Russ/40 is offline   Reply With Quote
Old 12-24-2020, 01:26 PM   #6
Jim Brierley
I also put a piece of thick foam rubber over the shifter, under the board, to keep the heat out.
Jim Brierley is offline   Reply With Quote
Old 12-24-2020, 01:54 PM   #7
California Travieso
Send a message via Yahoo to California Travieso
Hey Russ,
What did you use to make your mat? I have looked at some rubber mat material at Lowe’s that might work.
I was thinking of making separate mats for the top and bottom boards so I can remove the bottom without having to remove the whole mat. The last time I removed it part of it cracked.
David Serrano
California Travieso is offline   Reply With Quote
Old 12-24-2020, 03:01 PM   #8
Russ B
mine was made by upholstery shop. dark blue square weave carpet material and blue ribbed rubber mat i bought on internet (same ribbed pattern as running boards, but blue). Not much original about my 1929 cabriolet except for having a Model A four banger.
Old 12-24-2020, 04:15 PM   #9
Ruth
Originally Posted by California Travieso View Post
Hey Russ,
David Serrano
Snyder's sells untrimmed rubber floor mats if you are interested in something like that. Then your can cut your holes where they are needed.
https://www.snydersantiqueauto.com/P...earchByKeyword
Ruth
Old 12-24-2020, 04:52 PM   #10
Joop
Joop's Avatar
Great replies Thanks
[email protected]
Old 12-24-2020, 06:13 PM   #11
Chris Haynes
Chris Haynes's Avatar
Russ B,
Is that a Studebaker steering wheel?
1921 Runabout
1930 Tudor
Early 1930 AA
Speed costs money. How fast do you want to go?
Chris Haynes is offline   Reply With Quote
Old 12-25-2020, 01:06 AM   #12
Russ/40
Russ/40's Avatar
Hey Russ,
David Serrano
I don't recall exactly what the material was. It was a neoprene material. I was able to make it the exact size. A single piece of 1/4" or 3/16" material that will never tear when removed and reinstalled. My floorboards are the ones the venders sell, unmodified. I only had to modify the steel plate that finishes the final hole. The emergency brake handle ends up in the same place, and the shift tower is within an inch to the rear of where the model A tower would be. The material I used I purchased from McMaster Carr as a sheet that I cut to size. I chose a smooth, un-patterned material. My focus was a material that wont ever tear or dry out no matter how many times I removed it.
Old 12-25-2020, 02:46 AM   #13
California Travieso
Ruth & Russ/40,
Thanks for the very helpful information, and Merry Christmas and a Happy New Year to you and all the Barners.
David Serrano
Old 12-25-2020, 08:53 AM   #14
shew01
shew01's Avatar
Hey Russ,
David Serrano
To protect my carpet, I purchased a rubber door mat from Lowe’s and used the carpet as a template to cut the Lowe’s mat to match. It worked well.
shew01 is offline   Reply With Quote
Old 12-25-2020, 09:07 AM   #15
Joop
Joop's Avatar
Thanks for hijacking my post this way it stays on top :-)))
Merry Christmas
Old 12-25-2020, 11:15 AM   #16
Ernie Vitucci
Merry Christmas Joop...Frank Gemmell has a 39 transmission in his four door A that has traveled all over hell's half acre over the years. You might want to go take measurements from it...Ernie
Ernie Vitucci is offline   Reply With Quote
Old 12-25-2020, 03:00 PM   #17
Russ B
Originally Posted by Chris Haynes View Post
Russ B,
38 Stude center and spokes. I rolled a smaller diameter rim for it, welded it on, and Backwards Unlimited did the grip and rim color for me. The horn button is from a 34 Stude President. I made the outer column and welded the Studebaker shaft stub to the '56 Ford PU shaft. The steering wheel itself was quite a project to get, make, and adapt for what I wanted.
Old 12-28-2020, 02:45 PM   #18
Joop
Joop's Avatar
Awaiting Russ/40 pictures and template. :-))))
Old 12-29-2020, 12:30 AM   #19
Russ/40
Russ/40's Avatar
Sorry, I'll do it tuesday.
Old 12-29-2020, 04:05 PM   #20
Russ/40
Russ/40's Avatar
Here are the photos. I can send hard copy paper templates with your self stamped envelope.
From my '29RPU with '39 transmission.
