Old 12-02-2020, 11:52 AM   #1
Rick Leavitt
Rick Leavitt's Avatar
Default Oil filter
Hello, I have a 1941 Mercury with the Flathead V8, I cannot find the oil filter. I feel really dumb asking this question, but I can't find it. Was it common in 1941 not to add a filter to the motor?
Rick Leavitt is offline   Reply With Quote
Old 12-02-2020, 11:56 AM   #2
1stford
1stford's Avatar
Default Re: Oil filter
It was common for there not to be an oil filter. If there was one it would be a black canister attached to the head with head bolts. My 41 mercury does not have an oil filter.
1stford is offline   Reply With Quote
Old 12-02-2020, 12:24 PM   #3
Kube
Kube's Avatar
The filter (proper) looks like this although your '41 had different lines plumbed than the '40.
Old 12-02-2020, 12:25 PM   #4
Rick Leavitt
Thank you, I was going crazy trying to find it. I have seen picture of them mounted on the head. I guess mine does not have one. What oil weight do you use since there's no filter?
Old 12-02-2020, 12:27 PM   #5
Rick Leavitt
Beautiful Flathead Kube. I definitely do not have that type of filter.
Old 12-02-2020, 12:43 PM   #6
corvette8n
corvette8n's Avatar
I use 20-50 weight oil in my ‘41 Ford as the motor is tired and burns oil.
Any good quality name brand oil is way better than what was available in ‘41. I don’t have a filter on my car either.
Post a picture of your car when you get a chance.
Old 12-02-2020, 01:21 PM   #7
Kube
Kube's Avatar
Rick, I'm with Corvette8n in that I prefer 20w/50. You are certain to get a lot of differing opinions on this.
I'd suggest you simply change the oil a bit more often than "normal" and forget about installing a filter. Say, every 1000 miles.
Old 12-02-2020, 02:19 PM   #8
tubman
tubman's Avatar
I'll take a bit of a contrarian view on this, as I believe, given the type of use most of our cars experience, a "bypass filter" can be very beneficial.
If you are not concerned about originality, I would think an 8BA filter canister could be modified for use on an earlier engine. These seem to be fairly easy to find and not that expensive. They resemble the factory setups enough that the casual observer will never know, and they take an easily available element. The mount would have to be fabricated (unless you are lucky enough to find a '49 filter) and some steel lines bent up. You would have to be sure to find one with the junction block that contains the .060" orifice and the sending unit.
tubman is online now   Reply With Quote
Old 12-02-2020, 03:44 PM   #9
Rick Leavitt
Thank you,yeah there is only 41,000 miles on the car and motor. I will just change more often. Thanks again
Old 12-02-2020, 03:44 PM   #10
Rick Leavitt
Thank you,yeah there is only 41,000 miles on the car and motor. I will just change it more often. Thanks again
Old 12-02-2020, 03:47 PM   #11
Rick Leavitt
Thank you for the info.
Old 12-02-2020, 06:56 PM   #12
Ford Freak
It's 20w/50w for me too ! - F F
Ford Freak is offline   Reply With Quote
Old 12-04-2020, 06:12 AM   #13
fortyonerag
fortyonerag's Avatar
My 41 marks its territory just fine with 20w/50
fortyonerag is offline   Reply With Quote
Old 12-07-2020, 06:54 PM   #14
Rick Leavitt
20W50 it is. Thanks
