Old 04-09-2021, 09:03 AM   #1
russcc
Default Help identifying EV8 parts
I would like know what year and model the column drops are in the photo. Also what the exhaust manifold is for in the 2nd photo. Thank you
Old 04-09-2021, 09:21 AM   #2
Tim Ayers
Default Re: Help identifying EV8 parts
Middle drop is a '32.
Old 04-09-2021, 11:21 AM   #3
DavidG
DavidG's Avatar
Tim,
With respect, it is not a '32 column drop, but rather of a later vintage with a different on/off plate and lever and wider spacing of the attachment holes on top.
The one at the top of the photo is '33-'34 passenger car.
The exhaust manifold is the right side manifold for '32-'36 V8s.
Old 04-09-2021, 11:24 AM   #4
Ben38
Ben38's Avatar
The middle one looks like my ‘38
Ben38 is online now   Reply With Quote
Old 04-09-2021, 11:52 AM   #5
Tim Ayers
Originally Posted by DavidG View Post
Tim,
With respect, it is not a '32 column drop, but rather of a later vintage with a different on/off plate and lever and wider spacing of the attachment holes on top. The one at the top of the photo is '33-'34 passenger car.
Hi David:
Thank you for the correction. Both you and other member pointed that out to me. I guess I shouldn't post until I have my morning coffee. Haha.
Tim
Old 04-10-2021, 12:52 PM   #6
russcc
Thank you all. I believe the one on the far right is 1936. How about that long legged one on the far left ? Any ideas.
Old 04-10-2021, 02:46 PM   #7
FlatHeadCoupe
FlatHeadCoupe's Avatar
Far left is 40-47 large truck (1 1/2 ton)
FlatHeadCoupe is offline   Reply With Quote
Old 04-11-2021, 12:24 AM   #8
mercman from oz
mercman from oz's Avatar
Large photo of Early Ford Steering Locks and Ignitions Switches.
Old 04-11-2021, 08:13 AM   #9
Veeder
Far right column switch ass I believe is a 41
Veeder is offline   Reply With Quote
Old 04-11-2021, 09:25 AM   #10
deuce lover
deuce lover's Avatar
There is not a 41 pass car one in that pic he posted.
Old 04-11-2021, 01:10 PM   #11
Steve/IL
Steve/IL's Avatar
I believe the one in the middle is 39 passenger.
I've got the old car disease. Thankfully there's no cure!
Steve/IL is offline   Reply With Quote
Old 04-11-2021, 04:59 PM   #12
FlatHeadCoupe
The middle one is '38-'39 Passenger car; The one on the right is '36 pickup (will work on '37 pickup); also backwardly compatible with '35-early '36, but with reversed switch-on position)
Old 04-12-2021, 08:03 PM   #13
v8fordman
v8fordman's Avatar
With respect, the one on the right could be a '36 but not a '37. The drops for half ton pickups and passenger cars were the same in their respective years, but '36 and '37's are definitely different. The distance from the bolt holes to the column opening is greater on the '37. The steering tubes were the same for '35-'37 pickups, which were different from passenger cars.
One can not tell from the picture whether it is a '35 or '36... which are quiet similar. The '35 and '36 are different because the lock cylinder on most '35's is slightly shorter causing the well the cylinder goes into to be slightly shorter. This is visiable and distinguishable if you hold one of each beside the other simultaneously.
My guess is that this one is a '36 based on the Hurd lock cylinder.
v8fordman is offline   Reply With Quote
Old 04-13-2021, 05:33 PM   #14
russcc
That's what the tag on it said '36, but wanted to confirm. Thank you all.
Old 04-13-2021, 11:50 PM   #15
deuce lover
Here is a 40-41 pickup drop
