Old 09-09-2020, 07:19 PM   #1
Wheels of the Past
Default 46 pickup rear tube shock conversion bracket advice
After a long search, here are the aftermarket brackets I wanted for my 46 Ford pickup. Just wondering if anyone else had these same brackets on their truck and if maybe someone could post a photo of them all mounted up. Im not quiet sure how to mount them.
Wheels of the Past is offline   Reply With Quote
Old 09-10-2020, 12:00 AM   #2
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 46 pickup rear tube shock conversion bracket advice
Let's see if this won't help to get you headed in the right direction. The two brackets bolt to the front side of the crossmember as mounts for the upper shock eyes. Not sure why, but someone has modified the one on the left. If you need more encouragement, just holler back! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-10-2020, 11:41 AM   #3
skidmarks
skidmarks's Avatar
Duplicate post
skidmarks is offline   Reply With Quote
Old 09-10-2020, 11:42 AM   #4
skidmarks
skidmarks's Avatar
Another route that to me is easier, get the tube shock brackets off a 48 to 52 F1.
The chassis is basically the same and they changed to tube shocks in 1948
Those bracket you have will interfere with the rear leaf springs on your 46
Old 09-10-2020, 12:05 PM   #5
Tim Ayers
Those brackets the OP posted a pict of are missing the bolts. I'll try to take a pict. of what they look like.
Tim Ayers is online now   Reply With Quote
Old 09-10-2020, 02:46 PM   #6
skidmarks
skidmarks's Avatar
Picture is of the brackets style that works with the spring U bolts on a parrallel leaf spring chassis. These move the bottom of the shock closer to the center
The pictures of the other style have the shock out at the backing plate and will interfere with parallel leaf springs.
(The ones i have pictured, i think might.be fronts off a 53 to 56 )
Old 09-10-2020, 03:00 PM   #7
Tim Ayers
The left one is also bent. See how the one hole is oblonged?
Old 09-10-2020, 05:07 PM   #8
JSeery
JSeery's Avatar
Might take a look at this link: https://www.fordbarn.com/forum/showthread.php?t=177495
https://streetrodder.net/2011/05/12/...-shock-mounts/
http://www.2040-parts.com/ford-shock...-47-48-i84224/
Old 09-11-2020, 07:24 AM   #9
Fordestes
I too am planning the same install, I have the brackets pictured from a 51 pickup, but if they don't fit I am thinking the brackets will be a good pattern to make some similar to work with the parallel leaf springs.
Fordestes is offline   Reply With Quote
