Old 08-16-2020, 09:22 AM   #1
shoe box Jack
Default heat sending units
my heat gauge was reading hot all the time. I took the wire off the unit on the drivers side an all is good. The unit on the driver side must be shorting out?? Thanks for any info. Jack.
shoe box Jack is offline   Reply With Quote
Old 08-16-2020, 09:31 AM   #2
tubman
tubman's Avatar
Default Re: heat sending units
Well, it looks like you've found the problem. I expect you're planning on replacing the drivers side switch; the flathead has what amounts to two cooling systems and you should be able to watch them both.
Old 08-16-2020, 06:22 PM   #3
JSeery
JSeery's Avatar
Don't know about shorted out, it is a normally closed switch (set of points). It is more likely that it developed an open. Might check it over, it might just be a bad connection.
Old 08-17-2020, 07:03 AM   #4
shoe box Jack
Thanks for the info guys I will try to safe it. Jack.
Old 08-17-2020, 11:04 AM   #5
JSeery
JSeery's Avatar
Might start with checking it with an ohm meter, there should be very low resistance through the point, just the build up over time.
