Old 07-07-2020, 10:34 AM   #1
shoe box Jack
Default 49 horn
the horn on the 49 quite working. I under stand if you push down on the horn ring and turn left the horn can be removed then you can clean the contacts? when I remove the horn ring will anything fall out? thanks for any help. Jack
shoe box Jack is offline   Reply With Quote
Old 07-07-2020, 10:49 AM   #2
corvette8n
corvette8n's Avatar
Default Re: 49 horn
Did you try running power direct to the Horn?, my '41 also has a horn relay not sure if '49 does another point of failure. I would test all that before I took wheel apart. Could also be a broken wire in steering column.
Old 07-07-2020, 12:14 PM   #3
rotorwrench
rotorwrench's Avatar
Default Re: 49 horn
The horn ring will have a spring to hold the tension on it but it won't fly out after the tension is released. The rubber ring is the major problem.
This is a link for instructions by Bruce Lancaster and it's as good as it gets.
https://www.fordbarn.com/forum/showthread.php?p=681371
Old 07-07-2020, 01:42 PM   #4
shoe box Jack
Default Re: 49 horn
Thanks; Rotorwrench great info. Jack.
