Old 02-17-2020, 09:17 PM   #1
glrose67
Default 97 stromberg on a standard 28 -possible?
Hi Everyone, I've tried to see what's out there regarding this but it seems there are a few opinions. My motor is stock. Will a 97 work or should I look at an 81 Stromberg.Thanks
glrose67 is offline   Reply With Quote
Old 02-17-2020, 11:25 PM   #2
1929
Default Re: 97 stromberg on a standard 28 -possible?
My car ran better with the 97.
1929 is offline   Reply With Quote
Old 02-18-2020, 03:27 AM   #3
glrose67
Thanks 1929, I'm guessing you're running a fuel pump?
Old 02-18-2020, 05:14 PM   #4
1929
I was, but not needed as long as I don't go over 60mph for to long.
Old 02-18-2020, 05:20 PM   #5
Lawrie
Lawrie's Avatar
I run a 97 on my A ,no fuel pump ,it will run up hil,l on the flat, and full throttle right down to empty.
Do a search under my posts and see the float valve mod I did,
Lawrie
Lawrie is offline   Reply With Quote
Old 02-18-2020, 06:59 PM   #6
kooljunkguy
kooljunkguy's Avatar
I would recommend the new Strombergs made in England, a lot less trouble. They actually just started reproducing an 81 sized carb which I have yet to try but seems very good.
“If you wax your chassis you deserve to have your chassis waxed”
1931 Model A Standard Phaeton
1929 Model A Pickup
kooljunkguy is offline   Reply With Quote
Old 02-18-2020, 10:31 PM   #7
CWPASADENA
CWPASADENA's Avatar
A single "97" will work just fine.
If you were running a dual carb intake, 2 "81's" would work best.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 02-18-2020, 11:08 PM   #8
glrose67
Thanks for the suggestions guys!
Old 02-18-2020, 11:09 PM   #9
glrose67
Thanks Lawrie!
Old 02-19-2020, 12:22 PM   #10
Bud
Bud's Avatar
Location of Lawrie's Mod: https://www.fordbarn.com/forum/showt...loat+valve+mod
Bud is offline   Reply With Quote
Old 02-20-2020, 09:34 PM   #11
SteveB31
SteveB31's Avatar
Use one 97, or two 81 carbs on a Model A. You can use two 97 carbs, but must run them lean.
SteveB31 is offline   Reply With Quote
