Old 02-05-2020, 04:38 PM   #1
Ian in Mississauga
Default spark plug caps
Hi all, I was just looking at a Restoration Supply Co. catalog and noticed something called “spark plug caps”. I must admit I like the look of 3X and other vintage brass capped spark plugs. Anybody ever use these to dress up modern replacement plugs? What are your thoughts?
Thanks, Ian
Ian in Mississauga is offline   Reply With Quote
Old 02-05-2020, 05:11 PM   #2
J Franklin
J Franklin's Avatar
Default Re: spark plug caps
Whatever suits your fancy. If they were given to me I would use them.
J Franklin is online now   Reply With Quote
Old 02-06-2020, 07:51 AM   #3
Bob-A
Bob-A's Avatar
I bought a set then realized you can make your own. It has been a while but I believe you use 1/2" copper plumbing end caps. I eye-balled what I thought was the inside center of the end cap. Marked it with a sharp punch then drilled a hole for the spark plug contact to stick through. If the hole was off center I rat tail filed it until if fit better. I use them on my W18 Champion plugs.
Bob-A
Bob-A is offline   Reply With Quote
Old 02-06-2020, 12:27 PM   #4
The Master Cylinder
The Master Cylinder's Avatar
I like that, Bob-A
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 02-07-2020, 09:28 AM   #5
Bob-A
Bob-A's Avatar
Smile Re: spark plug caps
Here are 8 "Champs" waiting for use. On a bookcase in my "Command Bunker", man caves are for sissies....
Bob-A
Old 02-07-2020, 09:45 AM   #6
leo
leo's Avatar
You can buy a set of those spark plug caps from one of the vendors and re-tap them to fit your modern plug. It's only brass, soft metal. I did this once but you will have to determine the thread size of your modern plug.
leo is offline   Reply With Quote
Old 02-07-2020, 01:09 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Default Fun with spark plugs.
I had some of those caps so I tried one out. It really changes the look of the plug. I had darkened the base in the past to look more aged. The screw on top came from the hardware store also.
Thanks for the tip, Bob-A.
Old 02-07-2020, 01:50 PM   #8
Y-Blockhead
I like it! Here they are on W16Ys.
Old 02-07-2020, 02:08 PM   #9
redmodelt
redmodelt's Avatar
I was wondering how they would look with 1/2 copper pipe caps.
Old 02-07-2020, 07:19 PM   #10
KGBnut
KGBnut's Avatar
I have thought of doing something like that. I like your execution of it. It looks sharp. I may give that a try.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 02-07-2020, 08:59 PM   #11
DNLs1930
DNLs1930's Avatar
Look pretty dang kool!!
Question: Do they get "energized" each time a spark travels to the plug and I must guess they do not affect the strength of spark available at the business end of the spark plug that might affect engine operation.
DNLs1930 is offline   Reply With Quote
Old 02-07-2020, 09:18 PM   #12
Y-Blockhead
Thanks, I just took Bob-As idea and ran with it. I am pretty pleased with how they look.
I'm sure they get "energized" just like a brass capped 3X Champion but should not effect the running of the engine, unless you ground them... I certainly wouldn't touch them if you have a pacemaker (I do).
Old 02-08-2020, 09:11 AM   #13
old31
Y and Bob, where did you get your caps and nuts?
I looked on restoration supply and only found the nuts.
I hate, despise, dislike and their site angers me. Why don't they do something like Snyders and make it easy to purchase from them.
Old 02-08-2020, 09:33 AM   #14
Bob-A
Bob-A's Avatar
Thumbs up Re: spark plug caps
Y-Blockhead, What brand of black paint did you use on the plug bases?
old31, The caps (1/2" copper pipe end caps) came from a plumbing supply store. Most all hardware stores should have them. The knurled nuts I bought from either Bratton's or Snyder's.
Bob-A
Old 02-08-2020, 11:02 AM   #15
Y-Blockhead
Bob-A
I used a light coating 'Black Onyx Patina for all metals'. Update: Don't use this paint. I was just polishing my copper caps with Nevr-Dull and it took this paint off!!
I can imagine any semi-gloss black would work if it could stand up to a little warmth..
Old 02-08-2020, 11:15 AM   #16
katy
katy's Avatar
Default Re: Fun with spark plugs.
oops, wrong heading, my bad.
Old 02-08-2020, 11:17 AM   #17
1928Mik
1928Mik's Avatar
Wow,those look nice. Cool idea. I just went to the local "Do It Center" and found the 1/2" caps and the knurled brass nuts all for the price of 7 bucks to make those myself.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 02-08-2020, 12:53 PM   #18
Y-Blockhead
Awesome. I put a ˝" drill bit in my drill press and without turning it on pressed down on the inside of the cap to mark the center. Tamp, tamp, turn tamp tamp... Then drilled it from the inside with 5/16" drill bit.
Old 02-08-2020, 07:28 PM   #19
old31
Y- very clever!
Old 02-09-2020, 12:36 PM   #20
DBrer
That is a great way to find the center.
DBrer is offline   Reply With Quote
Thread Tools
Display Modes
