09-15-2018, 03:43 PM | #1 |
U-joint Play
Pulled the trans forward to check my U-joint while the engine is out and found that while there is very little rotational play there is quite a bit (at least to my mind, maybe 1/16") of vertical play. Just wondering if this is acceptable, never dealt with one of these before.
Also, will this fit the A? https://www.snydersantiqueauto.com/r...int-gasket-set Nothing else comes up when I search and I'd like to change the felts in the housing Last edited by ryanheacox; 09-15-2018 at 03:52 PM. |
09-15-2018, 05:23 PM | #2 |
Re: U-joint Play
Here's the gaskets for the A. https://www.snydersantiqueauto.com/universal-gasket-set
The yokes will slide quite a bit side to side on the cross. Bob |
09-15-2018, 05:54 PM | #3 |
Re: U-joint Play
I seem to recall that there's a little play in the seal on the driveshaft. Sort of like the rear axles. No? Wrong?
09-15-2018, 09:27 PM | #4 |
Re: U-joint Play
It's a feel thing. Hard to explain. If the x in the middle is standing up and your holding the joint in your hands, there will be a sliding movement- side to side in 2 directions. that's OK. If the ends of the cross are sloppy in the cups of the yolk or feels rough that is wear. Model As often have destroyed joints and never felt a thing for years, Also, the replacements have been an issue in the last few years and were unavailable for a while.
09-16-2018, 06:25 AM | #5 |
Re: U-joint Play
Concerning only the joint, Axial play is normal, rotational play is not. It should also move move smoothly.
09-16-2018, 06:47 AM | #6 |
Re: U-joint Play
Bob Bidonde |
09-16-2018, 09:25 AM | #7 |
Re: U-joint Play
Aren't U-Joints AMAZING! Whoever invented them should get 3 GOLD STARS! And just think, MANY U-Joints are bolted to the rear end, with just 4 REALLY SMALL fine thread bolts!!! (Almost scarey!)
In past years it was common to dismantle & re-pack the cups with grease & then they got SMART & made them with a GREASE FITTING! It takes TALENT to take them apart & put them back together again! Bill Amazedagain
09-16-2018, 10:09 AM | #8 | |
Re: U-joint Play
I've repacked them for decades. Usually once is enough to last the life of the vehicle, well, most vehicles. |
09-16-2018, 02:03 PM | #9 |
Re: U-joint Play
Thanks everybody, exactly what I was hoping to hear. Looks like all I'm going to need is a gasket set.
