Old 03-29-2018, 06:28 PM   #1
Ian in Mississauga
Default Vacuum gauge reading with a Model B distributor
I always hook up a vacuum gauge at the start of the season as a diagnostic tool. With a model A distributor I get a range of about 16" to 20". Recently I installed a model B distributor. What numbers are normal with this set up?
tia, Ian
Ian in Mississauga is offline   Reply With Quote
Old 03-29-2018, 07:17 PM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Vacuum gauge reading with a Model B distributor
I don't see where there should be a difference. We're talking about engine condition not ignition system. The base timing is advanced more than an A, thats all.
Old 03-29-2018, 08:40 PM   #3
michael a
michael a's Avatar
I always set my distributor at the highest point of vacuum this is an FSI unit with flyweight advanced positive High Point at idle
Sent from my SM-J700T using Tapatalk
michael a is offline   Reply With Quote
Old 03-30-2018, 08:49 AM   #4
SeaSlugs
SeaSlugs's Avatar
http://www.onallcylinders.com/wp-con...-reading-1.png
invaluable tool. Between a compression tester, leakdown tester, and a vacuum gauge you can tell everything there is to know about any engine and anytime a suspected engine issue, backfiring, overheating, or low power these 3 basic tests should be run. Easily do all 3 in less than an hour.
Link is a great chart you can print off and pin to the garage wall or wrap the vacuum gauge in it.
Model A has an easy access vacuum port right on the manifold so it cant get any easier.
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 03-30-2018, 11:10 AM   #5
Corley
Huh? "Splain yourself Lucy?"
Corley is offline   Reply With Quote
Old 03-30-2018, 03:18 PM   #6
100IH
Comparing distributors is, to me a fuzzy thing because the A with the manual advance will be all over the map for vacuum depending where basic is set and where lever is set. B same thing for basic timing and except for all of the variables in camshaft profile, timing covers and A vs. B block variables and condition of centrifugal timing on B dist. Like comparing track shoes to horse shoes.
I commend your use of the vacuum gauge though.
100IH is offline   Reply With Quote
Old 03-31-2018, 04:12 AM   #7
michael a
michael a's Avatar
Have you ever used the vacuum gauge
Old 03-31-2018, 07:05 AM   #8
Corley
Only for the last 60 years or so. (I'm 78 now, been wrenching most of those years.) However, your sentence did not make sense to me. Positive? What's that about??? I've never found highest vacuum reading to be the optimal timing set point. In fact on many engines, timing and vacuum readings are not really related at all, unless timing is way out.
Being a Jr member here does not imply one is new to As or mechanics, only that one tends to not post much.
