Old 08-28-2017, 11:03 AM   #1
Ian in Mississauga
Default Point gap and timing
Anybody know just how much a change in the point gap affects the timing? I recently opened up my gap to .020"and the first time I drove over 45m.p.h. the engine stumbled until I retarded it a few clicks. Sorry, I didn't measure the point gap to begin with but the engine ran fine.
Ian in Mississauga is offline   Reply With Quote
Old 08-28-2017, 11:39 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Point gap and timing
Always set the points first to .020", then set the timing. From then on you shouldn't have to even thing about checking the timing, just reset the points to the correct .020" clearance. Only if the distributor cam is loosened do you have to reset timing.
Old 08-28-2017, 12:25 PM   #3
40 Deluxe
But, "setting the timing" is an age-old ritual that many go through because it makes them feel that they are accomplishing something. You know: Buy the gadgets, hold one's tongue just right, then fiddle and refiddle! "Ah, perfect!" Then start the engine, pull the lever down and thus change everything!
Old 08-28-2017, 12:32 PM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I find a lot of engines like the point gap a little less than .020.
Jacksonlll is offline   Reply With Quote
Old 08-28-2017, 03:27 PM   #5
40 Deluxe
That's possibly because the coil is weak and needs the extra dwell time to build up voltage.
Old 08-28-2017, 09:09 PM   #6
Richard Lorenz
One thousandth point gap change affects the dwell by 2 percent with a "B" distributor cam.
Richard Lorenz is offline   Reply With Quote
Old 08-29-2017, 02:21 PM   #7
Jim/GA
Jim/GA's Avatar
2 percent or 2 degrees?
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 08-29-2017, 04:34 PM   #8
Patrick L.
Patrick L.'s Avatar
I'm thinking that if the engine stumbles with much advance and runs better when its retarded a bit, there is a problem that is not connected with the point gap.
I would think there is a primary wiring issue or it could be a weal coil issue. But I would still at other things before the coil.
Old 08-29-2017, 05:55 PM   #9
Dick Steinkamp
Dick Steinkamp's Avatar
One degree of dwell is equal to 1 degree of initial advance.
For each degree of dwell increase, the spark is retarded by one degree at the crank.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 08-31-2017, 11:30 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
A narrower gap gives more dwell and a wider gap gives less. Taking it to extremes, excessive dwell means that the points close too soon after opening, cutting off the magnetic field collapse before it delivers all its energy. Too little dwell gives the magnetic flux insufficient time to build up to the maximum.
Both conditions give a weak spark which gets even weaker as the engine RPM rises and produces misfiring at normal operating speeds.
Old 09-01-2017, 10:34 AM   #11
katy
katy's Avatar
Speaking of dwell, does anyone know what the dwell would be, with an A cam? With a B cam?
Old 09-01-2017, 11:09 PM   #12
Mike V. Florida
https://www.fordbarn.com/forum/showthread.php?t=79479
