04-21-2015, 09:03 AM | #1 |
testing trans and differential on jack stands
Is it safe to test a car's trans and differential while the car is support by 4 wheel jack stands.. or is it safer to only lift up the rear and support each wheel axle by jack stands??
04-21-2015, 09:42 AM | #2 |
Re: testing trans and differential on jack stands
Personally I would keep those front wheels on the ground and "chocked". Vehicle is much more stable and less apt to vibrate off the stands. Point it towards an open field, not your wife's car.
04-21-2015, 09:49 AM | #3 |
It depends on what the definition of is is and I didn't have sex with that woman !!
Chisel Evil Lurks...for those that don't carry a side arm!!! |
04-21-2015, 10:09 AM | #4 |
I've done it that way a lot. No problem.
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
04-21-2015, 10:14 AM | #5 |
Just asking...will do only as a last resort.
I have a lot of things to try first. |
04-21-2015, 11:32 AM | #6 |
'52 F-1, EAB flathead |
04-21-2015, 11:52 PM | #7 |
In order to test the shift pattern of the transmission in my 40 Tonner I put the front wheels on the Harbor Freight ramps I use for draining the oil and the rear axle on HD jack stands. All the gears in the trans were tested at idle and at 1/2 throttle. Even in 3rd gear at 1/2 throttle this setup seemed to be secure with no danger of falling off the supports.
04-22-2015, 02:12 AM | #8 |
I've had my car running in gear with all four wheels off the ground, no problem.
04-22-2015, 10:04 AM | #9 |
Given your self-expressed unfamiliarity with things mechanical, there are too many things that can go wrong in either case (2 wheels off the ground or all four) hence this is a very bad idea for a DIY project.
04-22-2015, 11:26 AM | #10 |
I was chasing down a vibration in an OT AWD car. Had it up on 4 stands with all 4 wheels spinning up to 80 mph while laying under the car looking/feeling for vibrations.
As the saying goes.... "don't do this at home, these guys are trained professionals" |
04-22-2015, 11:47 AM | #11 |
there is a reason that women generally outlive men.
tom |
04-22-2015, 04:13 PM | #12 |
Once had a round track car up on stands under the rear end and guess what, it came down off, I jumped back after reving it and when it hit the ground it killed the motor, guess the alum. flywheel saved the day!
04-22-2015, 05:58 PM | #13 |
When I did AAA on the weekends I'd get a call to unlock a car, running, on jackstands. Interesting.
Paul in CT |
04-22-2015, 06:09 PM | #14 |
What's a rednecks famous last words? "Hey watch this!!!"
Seriously though, please be very careful doing this. Have really good quality jack stands, don't rev the hell out of the engine, and block the front wheels as already mentioned. |
04-22-2015, 08:27 PM | #15 |
I've done it a couple times with no problems
(Knocking on head errr "wood") Just pay attention while doing it! Good luck and be careful Randy |
04-22-2015, 09:09 PM | #16 |
When I poured the slab for my shop I installed a 'deadman', which is a strong forged eyebolt for attaching a chain or cable to. The two times I've run a truck on jackstands I utilized this for safety. I learned this deadman term from working in boatyards when I was a kid. They were planted all over the place for snatch blocks etc.
04-23-2015, 04:49 AM | #17 |
All those that had a problem are not responding
04-23-2015, 06:16 AM | #18 |
That's too funny, yet sadly true!
Thank God this is only a hobby! |
04-23-2015, 06:29 AM | #19 |
Going back to around 10yrs old all us kids had a back field machine. These were
5 dollar cars dime a dozen. So my friend gets a free nice straight 1936 Chev 4 dr. first thing He figures is how fast will it go, so jacked up with a bumper jack he proceeded to hit around 80 on the speeometer ha ha, He had babbit pounder parts all over the yard Yes he got a beat'n from his old man.......and he never got to drive it. |
