Old 12-24-2020, 02:40 AM   #1
aussie merc
aussie merc's Avatar
Question voltage control for gauges
just a quick question runtz type voltage drops how many king sealy gauges will one run successfully
aussie merc is offline   Reply With Quote
Old 12-24-2020, 07:48 AM   #2
fortyonerag
fortyonerag's Avatar
Default Re: voltage control for gauges
Not sure on this, but each seem to be made for a single guage only.
What do you have in mind?
fortyonerag is offline   Reply With Quote
Old 12-24-2020, 09:09 AM   #3
Bursonaw
Bursonaw's Avatar
The instructions are very clear only one per gauge.
Sent from my iPad using Tapatalk
Bursonaw is offline   Reply With Quote
Old 12-24-2020, 11:14 AM   #4
19Fordy
19Fordy's Avatar
If you are converting from 6 to 12 V use a CVR. Use a Ron Francis CVR (constant Voltage reducer) for best results. Read this:
https://www.fordbarn.com/forum/showt...oltage+reducer
Do a search on Constant Voltage Reducer and tons of info. appears.
Old 12-24-2020, 12:55 PM   #5
estout81
Use what Ford used, starting in '57. NAPA # IR1.
estout81 is offline   Reply With Quote
Old 12-24-2020, 01:23 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
Ditto on the NAPA IR1, takes care of all the gauges.
Old 12-25-2020, 06:17 AM   #7
aussie merc
thanks one per gauge need to get gauges working correctly on 39 mercury
