Old 08-06-2020, 01:10 PM   #1
shoe box Jack
Default 94 carb.
the two low speed idle jets on the back off the carb. is two and 1/2 turns out enough ?. thanks for any info. Jack.
shoe box Jack is offline   Reply With Quote
Old 08-06-2020, 01:34 PM   #2
alanwoodieman
Default Re: 94 carb.
start with 1 1/2 turns out from a gentle seating--just did two 94's and never moved the screws after firing up
Old 08-06-2020, 01:34 PM   #3
TitusDH
That‘s more than adequate. Most people start at 1-1.5 turns from a light seating. Then go for the highest idle rpm or preferrably the highest manifold vaccum reading.
TitusDH is offline   Reply With Quote
Old 08-06-2020, 01:43 PM   #4
tubman
tubman's Avatar
I would think that if you have to run 2 1/2 turns out, something isn't quite right.
Old 08-06-2020, 03:08 PM   #5
frnkeore
frnkeore's Avatar
I agree.
The old way, w/o a vacuum gauge, is to set the idle as low as you can, first then, start at 1 1/2 turns and turn the screw in, until the revs drop, then turn it out, the same way. Count the turns and set it in the middle. Do it twice, after the first time, reset the idle.
You didn't say if it's one carb, or more. With two or more carbs, you have to set the throttle plate opening, first.
Frank
'35 Ford Model 51
'48 Ford F3
'54 Ford Tudor Mainline
frnkeore is offline   Reply With Quote
Old 08-07-2020, 02:44 PM   #6
shoe box Jack
Hi . I set the idle at 500. The vac. gauge read 19 in. the rpm now is 700 the dwell is 34 ?? is that good or ok. dis. is a chev. the air scews are 1 1/2 turns out. starts and runs good. thanks again Jack.
Old 08-07-2020, 03:28 PM   #7
jimvette59
jimvette59's Avatar
Now you can slow the idle down .
jimvette59 is offline   Reply With Quote
