07-18-2020, 11:44 AM | #1 |
power valve
I'm replacing the pv. in the 94 carb. I have the pv. fairly tight and it still seeps a little, how tight should it be??. thanks for any info. Jack.
07-18-2020, 12:06 PM | #2 |
Re: power valve
Good luck. It seems many of the rebuilding PVs have too much of an angle at the base of the threads preventing the gasket from sealing also the soft gasket supplied often leaks. Charlie Schwendler may have a good gasket.
07-18-2020, 12:26 PM | #3 |
Re: power valve
You probably have a later power valve. They look the same, but the sealing area is slightly different from the proper early valves and they will leak. As long as you're getting a gasket from "Charlie ny". you might as well get a power valve too.
07-18-2020, 12:41 PM | #4 |
Re: power valve
You want one like the one on the right with no radius at bottom
Al |
07-18-2020, 03:11 PM | #5 |
Re: power valve
thanks guys for the come back. Tubman how do I get in touch with charlie ny. Thanks again Jack.
07-18-2020, 03:34 PM | #6 | |
Re: power valve
07-19-2020, 08:48 AM | #7 |
Re: power valve
Thanks Petehoovie. Jack.
07-19-2020, 09:32 AM | #8 |
Re: power valve
That's a great comparison picture, Al. Everyone with a Holley carb should save a copy.
07-19-2020, 11:43 AM | #9 |
Re: power valve
Also, Charlie ny prefers the power valves that have four small side holes instead of the two large square windows.
Sal |
07-19-2020, 02:31 PM | #10 |
Re: power valve
I believe the correct Power Valves and quality carb kits may also be purchased from Daytona Auto Parts:
https://daytonaparts.com/ |
07-19-2020, 08:22 PM | #11 |
Re: power valve
I just went through troubles with my 94. I sent my carb to Charlie. Got it back last week and the car runs great.
Sent from my SM-N950U using Tapatalk |
07-20-2020, 11:55 AM | #12 |
Re: power valve
Charlie did my two 94's, work great! he is the man
