Old 06-10-2019, 05:12 PM   #1
flat 39
flat 39's Avatar
Default oil in cylinder
What would cause one cylinder to ingest oil like this? Install rings backwards?
flat 39 is offline   Reply With Quote
Old 06-10-2019, 06:45 PM   #2
19Fordy
19Fordy's Avatar
Default Re: oil in cylinder
Yes, I bet it's ring related. Is the cylinder wall scored? Broken ring?
Old 06-10-2019, 07:22 PM   #3
Bored&Stroked
Bored&Stroked's Avatar
Hmmmmm . . . if you have the typical 3-piece oil ring setup (2 rails and an expander), they can't go in backwards - there is no orientation. You didn't happen to check the compression before you pulled the heads did yah? I'd want to know if that cylinder was holding compression the same as the others. If the oil isn't coming by the rings, then the next obvious place is through the intake guide. It looks like it is the rear cylinder, so I'm wondering if your engine has the oil baffles installed in the valley area? Maybe you're throwing a lot of oil up into the valley - and a "loose" guide or one with no seals on it is pulling oil into the cylinder? What type of crankcase breather system are you running? Is it a stock 49-53 setup with the oil draft tube . . . or???? Just some things to think about . . .
Old 06-10-2019, 07:34 PM   #4
flat 39
flat 39's Avatar
B&S
It is three ring pistons and I did not check compression.
I will pull the intake and check the valve guide.
also, I am using a PCV system that ports into the vacuum port on an Offenhauser regular dual intake.
Thanks for your input.
Old 06-10-2019, 07:43 PM   #5
Bored&Stroked
Originally Posted by flat 39 View Post
B&S
Are you running a late style 49-53 manifold that uses a PCV in place of the road-draft tube? The later system works bass-akwards from the earlier pre-49 system - lots of folks mix-match parts and then their whole breathing/venting system is compromised.
Old 06-10-2019, 08:07 PM   #6
alanwoodieman
valve seal on intake, guide very loose in bore. I have seen this before and that is what it turned out to be. also would check to see if oil is draining back to oil pan from intake area, splash pans on the rail?
alanwoodieman is offline   Reply With Quote
Old 06-10-2019, 08:25 PM   #7
Jack E/NJ
Jack E/NJ's Avatar
That's a lot of oil sitting in there. How's the piston crown look? Jack E/NJ
Jack E/NJ is offline   Reply With Quote
Old 06-10-2019, 09:25 PM   #8
petehoovie
petehoovie's Avatar
What's with those dings I see in/on the top of the piston?....
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 06-11-2019, 08:01 AM   #9
flat 39
flat 39's Avatar
It is the '49-'53 style manifold with the PCV in the road draft port.
Old 06-11-2019, 08:06 AM   #10
flat 39
flat 39's Avatar
I believe the dings are from a spark plug electrode that hit the exhaust valve. It seams that that plug hole was bored a little deeper than the rest. I now have a copper washer under that plug.
Old 06-11-2019, 09:04 AM   #11
Jack E/NJ
Jack E/NJ's Avatar
So does that mean the plug broke off and banged around the cylinder? I think what we're getting at here is there perhaps a hole or crack thru the piston crown? Jack E/NJ
Old 06-11-2019, 12:41 PM   #12
Ggmac
It looks as if it was firing which I wouldn't think possible with all that oil in the hole . Is it the stock cam , any vacuum port to that intake runner ? Is the motor level , meaning in its stock location and not raised excessively in the front ? Was the oil level correct ? Not relying on the dipstick but on amount installed .
Ggmac is offline   Reply With Quote
Old 06-12-2019, 07:41 AM   #13
flat 39
flat 39's Avatar
Upon further investigation, It appears to be the result of a gunky PCV valve and a little over fill oil level. Waiting for new head gaskets to verify.
Old 06-12-2019, 08:13 AM   #14
Jack E/NJ
Jack E/NJ's Avatar
>>>What would cause one cylinder to ingest oil>>>>?
>>>>It appears to be the result of a gunky PCV valve and a little over fill>>>
But then shouldn't more than just that one cylinder be affected? Jack E/NJ
Old 06-12-2019, 01:36 PM   #15
Kurt in NJ
Kurt in NJ's Avatar
When a cylinder is passing oil by the rings a little will make carbon chunks, cover the top of the pistons , a little more will start washing the piston top clean around the edges, a lot of oil will wash the pistons clean
I have seen oil rings missing, the expander ends overlapping, pieces of rings broke off due to installation problems, std rings in .080 bores---- if that much oil is going in through the intake from the pcv there will be wet oil in the intake and port
Old 06-12-2019, 03:53 PM   #16
Jack E/NJ
Jack E/NJ's Avatar
Yep. Seems like a pretty clean and oily piston top & exhaust path. Intake not so much. Jack E/NJ
