Old 12-21-2013, 07:18 PM   #1
transbytip
Default trans
help identify this trans.it is 3sp.toploader Serial no fits 1940 it is short shaft with yoke for open d.s.Cliff transbytip
transbytip is offline   Reply With Quote
Old 12-21-2013, 07:29 PM   #2
Mike B
Default Re: trans
Maybe an older conversion...I think just shaft, rear housing and yoke are needed to convert from closed to open.
Mike B is offline   Reply With Quote
Old 12-21-2013, 07:35 PM   #3
Mart
Mart's Avatar
Default Re: trans
A better pic of the whole box would help, but It does look like a stock 3 speed, with some sort of industrial or marine conversion. I don't think that setup is a standard ford setup from a truck. The box may be able to be converted back to a conventional closed driveline.
Mart.
Old 12-21-2013, 08:05 PM   #4
40cpe
40cpe's Avatar
Default Re: trans
It was probably designed for some vehicle because it has a speedometer drive.
40cpe is online now   Reply With Quote
Old 12-21-2013, 11:27 PM   #5
alan
Default Re: trans
3 speed top loader from a 3/4 ton truck, 1940 and up. the rear mount and open drive line give it away. This is what is in my 41 3/4 . Same mount is used in open driveline 4 speed trans also 1940 up, this is what is in my 41 1 1/2 ton and my 1951 1 1/2 ton. these 78 cases were the ones that the old racers wanted--thicker bottoms and could be converted to closed driveline
alan is offline   Reply With Quote
Old 12-22-2013, 04:29 AM   #6
Mart
Mart's Avatar
Default Re: trans
Thanks for the info, would I presume that would have been the "light duty" option in a 3/4 ton??
Mart.
