Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 03-15-2021, 08:37 PM   #1
harper71
Default 28 A engine making noise
Hey guys my 28 roadster pickup started making a noise on the last tour I took. It runs just fine but sounds like the valves are clattering. I checked the valves and there ok and the noise seems to be comming from the front timing gear area. I looked in the side cover and nothing obvious, whats next pull the timing cover and look around?
harper71 is offline   Reply With Quote
Old 03-15-2021, 09:19 PM   #2
redmodelt
redmodelt's Avatar
Default Re: 28 A engine making noise
You have asked your question in a section that is not for car questions. Cut and paste it in to the Model A Forum. This section is for questions about the site, it's use or problems related. Some will read, few will reply. (Note the few names on the reply side, we generally do not answer questions in this section except to direct you to the correct place) have a nice day!
