Old 01-06-2019, 05:50 AM   #1
Steve Plucker
Default Ford's Texas Assembly Plants...
Using Google Maps, can someone in Texas in and or around Dallas and Houston, please point out Ford's Assembly Plants that are, or were, in each of those cities?
Address if possible.
Thanks.
Pluck
Old 01-06-2019, 09:00 AM   #2
Brian SATX
Brian SATX's Avatar
Default Re: Ford's Texas Assembly Plants...
Try this for Dallas http://www.motortexas.com/doc/ford-m...uilding-dallas
Here is the Google map. Looks like the building is gone. https://www.google.com/maps/place/52...!4d-96.7490574
Brian SATX
Brian SATX is offline   Reply With Quote
Old 01-06-2019, 09:05 AM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
For the Houston plant;
https://www.google.com/search?q=3900...&client=safari
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-06-2019, 09:07 AM   #4
Brian SATX
Brian SATX's Avatar
And this for Houston. https://en.wikipedia.org/wiki/List_of_Ford_factories
Google map https://www.google.com/maps/place/39...9!4d-95.335945 looks like the red brick portion could be original
Brian SATX
Old 01-06-2019, 09:56 AM   #5
29closedcabguy
29closedcabguy's Avatar
http://askus.thehenryford.org/faq/140528
Dates, addresses, and drawings.
29closedcabguy is offline   Reply With Quote
Old 01-06-2019, 12:33 PM   #6
Steve Plucker
Thanks guys for the help...got the information I needed!
Pluck
Old 01-06-2019, 12:41 PM   #7
jimalabam
jimalabam's Avatar
Steve: What else do you Texas locations, Dallas, Houston (Aribi) and Fort Worth. Did you get my cell # ??? Jim...
jimalabam is offline   Reply With Quote
Old 01-06-2019, 08:03 PM   #8
Jason in TX
Jason in TX's Avatar
The Model T plant in Dallas is now nice loft apartments. Adam Hats. Have had friends live there. Model T assembly from 1914 - 1925. After 1925, this location became a secondary location, warehouse and Ford show room until 1955
The newer assembly plant that assembled Model A Fords in dallas was at 5200 E. Grand Avenue. The last vehicle rolled off the assembly line there on February 27, 1970. It was a Ford F-100 pickup.
This location is now a warehouse and a recycling plant.
https://goo.gl/maps/2EJJ7wZWZqD2
The plant has grown now. The corner of the building in the above photo is about where the words "Texas Recycling" in this aerial photo below.
In the 1950s, the ford plant stuck these stickers on the Ford cars that came out of this facility.
File Type: jpg ORIGINAL-1950s-Vintage-FORD-car-Company-Built-in.jpg (20.6 KB, 130 views)
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 01-06-2019, 10:05 PM   #9
Steve Plucker
Thanks Jason...some nice photos!
How did you get the photo of the Google Maps shot?
Pluck
Old 01-07-2019, 12:52 PM   #10
Jason in TX
Pluck
Hi Steve. I took a screen capture of the map by hitting "CTRL + ALT + PRT SC" while on that window and then opened PowerPoint and hit "paste." You can then crop the image to get rid of the browser window header and other junk and then save the image as a .jpg.
Hope that makes sense. You can probably also past the screen capture in Word and do the same thing.
Old 01-07-2019, 01:00 PM   #11
Steve Plucker
Yes, Thanks...I figured it out.
Now the next question...As one sees the plant from the air on Google Maps...Is there a way to angle the photo from the air view to get a better shot rather than just a roof top photo?
Pluck
Old 01-08-2019, 02:34 PM   #12
Jason in TX
Pluck
Once you are on the aerial photo view, click on the "3D" button in the bottom right corner. That gives you a 3D view of larger populated cities. Rural areas don't have this feature work as well.
Old 01-08-2019, 05:17 PM   #13
Steve Plucker
Darn...I do not have that feature on my Google Maps site.
How does on acquire it?
Thanks.
Pluck
Old 01-08-2019, 06:01 PM   #14
Jason in TX
Thanks.
Pluck
I think it best works in the Chrome browser.
"Use hardware acceleration when available" had been disabled in Settings. <click><RELAUNCH>
1) go up to the top right corner of your Chrome browser, click on the three dots and select settings.
2) Scroll to the bottom of settings and select advanced.
3) Scroll to the bottom again under system and turn on "use hardware acceleration when available"
