Old 03-10-2024, 04:38 PM   #1
Seabees
Default '32 BB cab mounting bolts
Howdy boys, I just put the cab on the '32 BB I've been working on for WAY too long, but I have forgotten where the bolts with the coil springs go? Yup, I took lots of pictures but not of this of course. Any help would be appreciated! Pictures of course, would be nice! Thanks guys!
Seabees is offline   Reply With Quote
Old 03-10-2024, 05:00 PM   #2
totto
totto's Avatar
Default Re: '32 BB cab mounting bolts
Bolts with coil springs are used to mount the gas tank in cab.
totto is offline   Reply With Quote
Old 03-10-2024, 05:06 PM   #3
Seabees
They are too long for the tank. There was only one bolt on the tank with a coil spring, 3/8" if I remember correctly. The ones I have, that I believe came off of the cab, since they were in the can marked "cab bolts" are 7/16", have a washer, coil spring, and castle nut. The bolts are about 3.5-4" long.
Old 03-11-2024, 06:29 AM   #4
Cool 33
Cool 33's Avatar
Back of the cab.
Cool 33 is offline   Reply With Quote
Old 03-11-2024, 09:59 AM   #5
Seabees
Cool 33, so how do they mount? They are 7/16 bolts, but the holes are 3/8. Pictures would tell the story. Thanks.
Old 03-11-2024, 10:01 AM   #6
Seabees
totto, so now I'm curious. There was only one bolt on the tank that had a spring. The other two did not. Are they all supposed to have a coil spring? Thanks.
Old 03-11-2024, 04:00 PM   #7
DavidG
DavidG's Avatar
No, just one in the center hole on one side and two 3/8"-24 hex head bolts without springs on the opposite side.
Old 03-12-2024, 12:02 PM   #8
Cool 33
Cool 33's Avatar
I looked at my original 33 BB and they go thru from inside the cab and the spring, washer and nut go underneath in the frame. Mine look to be 3/8 where the nut goes on but can't see the whole length. If it were mine and they go thru the frame holes ok, I would just enlarge the holes in the cab floor.
Old 03-12-2024, 04:45 PM   #9
totto
totto's Avatar
David: THANKS for your input!
Old 03-12-2024, 07:00 PM   #10
Seabees
Thanks Cool 33. You were the first to correctly provide an answer. I just wanted to make sure. Thanks again!
Old 03-12-2024, 09:24 PM   #11
DavidG
DavidG's Avatar
deleted
Old 03-12-2024, 09:48 PM   #12
Seabees
Hey David G, this truck, which is an AAB does have the coil springs on the rear cab bolts. They are 7/16", about 3.5" long. Sugarmaker sent me some pictures of his, which is also an AAB. Thanks.
Old 03-13-2024, 02:12 AM   #13
sugarmaker
sugarmaker's Avatar
Folks,
I took these pictures of the cab mounts on our AAB 32 truck.
in the rear there is the spring and nut on the bottom of the frame as Cool 33 describes.
But on the front of the cab there is no spring
Regards,
Chris and Cheryl
1932 AAB Truck
1953 Ford Jubilee
2015 Ford F250 SuperCrew
Lots of Allis tractors
Some Cub Cadets
