03-12-2011, 09:59 PM | #1 |
AA axles worth anything?
I recently found 3 front axles and rear ends from some AA trucks. Some rears look like the have auxillary gears? The frames are there but really rough and cut up. The axles are complete with drums. Is is worth my time to dig them out and see if somebody could use them or should I just let them sleep longer?
Respecting and Resurrecting Ford Model A's. |
03-12-2011, 10:10 PM | #2 |
Re: AA axles worth anything?
asking here might get you an audience more likely to want them:
http://forums.aa-fords.com/ |
03-12-2011, 10:23 PM | #3 |
If the rear axles have the 5.14 rear end ratios, they are worth checking out further. Like Pat says go over to the AA board and you will get all kinds of good info.
03-13-2011, 05:37 AM | #4 |
I agree - if the rears have the 5.14:1 gears, they would be worth something, especially to an AA'er who'd like to go a bit faster. Also, if any of the axles have the later cast iron brake drums, they might be worth saving. You can ID those by the small, square-ish bumps cast in the drum, about 180 degrees apart, right where the drum meets the backing plate. The pressed steel drums do not have these there.
03-13-2011, 05:59 AM | #5 |
Even if they are the LOW speed axles...if any of the inside parts are fairly decent and still usable...I mean price some of those bearings or axles shafts out and you will see what I mean!...the only difference between a high speed and low speed are the drive gears themselves (ring and pinion and/or worm gear) plus the speedometer gear. (Did I miss anything?).
Pluck Last edited by Steve Plucker; 03-13-2011 at 06:43 AM. |
03-13-2011, 06:21 AM | #6 |
03-13-2011, 06:41 AM | #7 | |
Pluck |
03-13-2011, 07:09 AM | #8 | |
03-13-2011, 11:21 AM | #9 |
I will take some pictures of them and post them up.
03-14-2011, 04:50 PM | #10 |
Pull the speedo drive. The rear end ratio is stamped on them.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
03-14-2011, 11:33 PM | #11 |
Not sure the AA axles are worth much, been trying to gat $150 out of a front end and rear end for afew years. Not sure if it the rear is the later ratio or not. The drive shaft and torque tube were shortened to make a haysweep out of the chassis. Luckily the shortshaft and tube were in good shape and found a decent home. Rod
03-14-2011, 11:57 PM | #12 |
If any are bevel gear (ring and pinion, as opposed to worm driven) you can look around the seam where the two halves of the pumpkin come together for a stamped number. "736" indicates that there was a set of 5.14:1 gears in it at some point. I say "at some point", because I have a rear with that stamped on it, but someone swapped in a 6.6:1 gearset some time in the past. Same goes for the speedo gear. Both are good starting places, but by no means a guarantee. Luke
