Old 06-21-2015, 02:26 AM   #1
34 FORDOR
34 FORDOR's Avatar
Default Timing Lights
There has been a couple of posts recently about using timing lights .I would like to buy a light with dial back and built in tach that WILL work on my v8 with stock ign and on my model a with pertronics ign . I have a timing light with dial back similar to the one summit racing sells, works well but no tach. I also have a Innova 3568, the strobe works, but the tach and timing advance control are all over the place. The tach on my Uni-t ut107 multi meter will not give accurate readings either. The new modern equipment does not does not appear work on old ignition systems, to much electro magnetic interferance ? Any suggestions ?
34 FORDOR is offline   Reply With Quote
Old 06-22-2015, 02:51 PM   #2
Bertha
Bertha's Avatar
Default Re: Timing Lights
I've always used my Mac TL86 dial back, connected to a spare 12v battery and the strobe is nice & bright. My latest tune-up ended up at 8*btdc, 475rpm.
I then adjust the idle for smoothest running in gear. All stock ignition. Have never had a pre-ignition problem using modern e-free 89 octane.
Bob
..."they are only original once"
Bertha is offline   Reply With Quote
Old 06-22-2015, 03:03 PM   #3
scicala
scicala's Avatar
I know Snap-On makes a dial back timing light with tach, but probably costs a small fortune.
Sal
Old 06-23-2015, 06:57 AM   #4
chap52
chap52's Avatar
If all else fails you can pick up an inexpensive IR tach online. These units usually come with stick on reflective tape that you stick on your front pulley. Then just point & shoot to get the rpm reading. May not be as convenient as an all-in-one unit, but I find the one I got to work just fine.
chap52 is offline   Reply With Quote
