Old 01-12-2024, 07:50 AM   #1
drfromnc
Default What are these 34 Cab floor holes for?
Been wondering about these holes in floor of my 34 cab. They are behind seat riser. The two holes circled in red appear to have a reinforcement plate. The three circled in yellow are rectangular holes that have a tab that points to the ground.
I am planning to replace the underseat plywood you see part of in the picture with a steel and may make it large enough to extent to back of cab as well.
drfromnc is offline   Reply With Quote
Old 01-12-2024, 08:48 AM   #2
Model51
Model51's Avatar
Default Re: What are these 34 Cab floor holes for?
What body style is your cab? I assume it's a regular closed cab with 2 doors? Is your picture on the right hand side or left hand side of the cab?
Trucks often received lots of post-production modifications but maybe these are original.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 01-12-2024, 08:55 AM   #3
fordyford
The rectangular holes are for the 3 wooden boards that the seat back hangs on. Round holes are bolts to the frame. Are you planning to use an original style seat?
fordyford is offline   Reply With Quote
Old 01-12-2024, 09:00 AM   #4
theriddler56
Send a message via Yahoo to theriddler56
The rectangular holes are for the wood that the seat back goes against. The reinforced holes are where the cab bolted to the frame. Cab mounts were different locations between pickup and 1-1/2 ton cab.
theriddler56 is offline   Reply With Quote
Old 01-12-2024, 10:55 AM   #5
drfromnc
Yes closed cab. Closeup picture is of passenger side.
That makes sense but the cab wood I removed didn’t extend to those 3 holes. They must have been cut off or rotted off. And those round holes didn’t have any bolts in them when I got the truck but will add bolts.
The only part of the original seat I have is the seat riser minus the part of the riser that is the back piece that bolts on or was riveted on. I am currently building a seat bottom ( plywood with 2 holes cutout, Elasbelt weaved over holes, then foam, Dacron, and then fabric) that is same size and shape as riser but with some sort of spacer along the front to raise the front of seat cushion about an inch or so. Probably 1” square tubing attached to front edge of original riser. Also planning to make a support bracing for middle of seat bottom (from to back) and bracing along back edge of seat bottom that essentially will take the place of missing back panel of original riser.
Old 01-12-2024, 12:01 PM   #6
petehoovie
petehoovie's Avatar
Old 01-12-2024, 12:03 PM   #7
petehoovie
petehoovie's Avatar
Old 01-13-2024, 09:15 AM   #8
drfromnc
I checked yesterday and the reinforced holes in the cab don’t have corresponding holes in the frame rail or crossmember.
Old 01-13-2024, 01:53 PM   #9
Newc
Newc's Avatar
My 34 PU same deal. Those reinforced holes are for the BB big truck I believe. Newc
Newc is online now   Reply With Quote
Old 01-13-2024, 03:00 PM   #10
34pickup
34pickup's Avatar
This might help:
Matt 24:36-41
34pickup is offline   Reply With Quote
Old 01-13-2024, 03:11 PM   #11
DavidG
DavidG's Avatar
And/or this:
File Type: jpg 34 closed cab seat back brackets - 3.jpg (80.1 KB, 236 views)
Old 01-13-2024, 07:19 PM   #12
petehoovie
petehoovie's Avatar
Originally Posted by 34pickup View Post
This might help:
Old 01-13-2024, 07:21 PM   #13
petehoovie
petehoovie's Avatar
Originally Posted by DavidG View Post
And/or this:
Old 01-13-2024, 08:46 PM   #14
drfromnc
Thanks all. Yes pictures help a bunch. Could I get a picture of the end of one of the three vertical pieces where it goes into or touches cab floor?
34pickup, what type of seat do you have in your pickup? Original or custom?
I am wondering how I might attach a homemade seat back to existing wooden cab structure?
Old 01-14-2024, 12:16 AM   #15
34pickup
34pickup's Avatar
My seat bottom frame is original.
Does this help?
Matt 24:36-41
Old 01-14-2024, 01:07 AM   #16
petehoovie
petehoovie's Avatar
Does this help?
Old 01-14-2024, 08:38 AM   #17
drfromnc
Does this help?
Yes thanks
Old 02-13-2024, 05:11 PM   #18
drfromnc
So I have a follow up question on those 3 vertical support that go into the holes in cab floor? Do they extend through the hole and the end of it rest on the frame rail? Or just extend into hole just below hole opening? Or tapered on the end to wedge fit into hole?
Thanks.
Old 02-14-2024, 12:32 AM   #19
34p-kup
Mine extend into hole 3/4", just enough to get a wood screw through the tab so they don't rattle.
34p-kup is offline   Reply With Quote
Old 02-14-2024, 08:50 AM   #20
drfromnc
Now that makes a lot of sense. I’ve not noticed there was a hole in the tab below the floor. Thank you.
