03-31-2018, 01:47 AM | #1 |
How do I back flush early V-8?
Have an 8BA in my '36 and would like to back flush cooling system, there are no heater hoses, could I attach garden hose direct to heads and back flush through and out the the radiator fill?
03-31-2018, 09:49 AM | #2 |
Re: How do I back flush early V-8?
I would pull lower hose to keep anything from going in radiator.
03-31-2018, 10:51 AM | #3 |
03-31-2018, 12:06 PM | #4 |
Flush everything both ways. Taking off the bottom hose. use a rag around your hose to add some pressure. When you flush the opposite direction from the normal flow you will be surprised at the debris coming out.
04-01-2018, 07:12 AM | #5 |
There are some creative ways of cleaning and flushing a radiator on "You Tube".
I would start by disconnecting the hoses and blocking the bottom outlet closed, filling the radiator with vinegar, let it soak (even overnight) then rinse with a water and baking soda mixture will break some of the junk loose. Follow that by flushing it a few times with water. |
04-01-2018, 08:37 AM | #6 |
04-01-2018, 07:31 PM | #7 |
I let mine cool before draining water, parked by the swimming pool. Hooked up pool filter discharge to hose connection on head mounted pumps ('36 lb) & blasted it through out the bottom. Also went backward through the radiator. Mice had put pink fiberglass in block.
