Old 04-17-2021, 02:08 PM   #1
Ardun
Ardun's Avatar
Default PCV For ARDUN
Anybody put a PCV Valve on an ARDUN converted 8ba Flathead? How did you do it without destroying the original intake cover or valve covers?
Tom
Ardun is offline   Reply With Quote
Old 04-17-2021, 02:23 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: PCV For ARDUN
Tom I run a PCV on my ARDUN I located it in the valley cover just in front of where the stock fuel pump mount is located. My valley cover is home made and the PCV I used was threaded on the cover end so I just added the thread and screwed it in place. You could do it the same way on the original ARDUN valley cover the threaded hole is not big in other words no destruction of the original cover is needed.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 04-17-2021, 09:07 PM   #3
Ardun
Ardun's Avatar
Ronnieroadster
Thanks. Seals arrived, thank you. Are your using an 8ba block? Any pics?
Old 04-17-2021, 09:10 PM   #4
Ronnieroadster
My block is a 59A but the same idea will work on the 8BA using the valley cover. I will try and get a picture.
Old 04-17-2021, 09:41 PM   #5
Ardun
Ardun's Avatar
Thanks. My concern in the different crankcase venting on the 8ba
Old 04-18-2021, 10:18 AM   #6
flatrod
flatrod's Avatar
Here is how I did mine. Its a home made valley cover, well a lot of home made parts.
flatrod is offline   Reply With Quote
Old 04-18-2021, 11:13 AM   #7
Ardun
Ardun's Avatar
Nice. More detail?
Old 04-18-2021, 05:02 PM   #8
flatrod
flatrod's Avatar
Austin blower manifold, I intend to put a blower on it, but made the 3x2 to run without the blower. The PVC valve is as I remember is slant 6 because it was the smallest I could find to fit where I have it. Its all a tight fit. There is a baffle under the valley cover so it don't suck up oil. Still have to put a filler/vent pipe in the back of the valley cover. I have a original valley cover but it gets in the way of everything, so I made up a new one.
Old 04-18-2021, 05:20 PM   #9
Ronnieroadster
Heres how I did my PCV installation it screws into the home made valley cover follow down the copper tubing to see it. Also located off the copper tubing is the engine vacuum gauge. Everything else for the Large SCOT blower assembly is also home made your typical back yard Hot Rod project. As I wrote previously Tom there's no difference between the 59A or 8BA when it comes to venting the crankcase in our applications.
Ronnieroadster
