Old 04-15-2021, 08:58 AM   #1
rottenron36
rottenron36's Avatar
Default Signal-stat 900 turn signal on positive ground
I am installing an older stat 900 in a 36 pickup positive ground. I have read some have had problems with he indicator light not working. I haven't tested mine yet. Anyone with experience with this type of signal, Please chime in. Thanks Ron
rottenron36 is offline   Reply With Quote
Old 04-15-2021, 09:42 AM   #2
51woodie
51woodie's Avatar
Default Re: Signal-stat 900 turn signal on positive ground
I have a 5007R in my '46 Coupe when I bought it, and the indicator didn't work. A bit of troubleshooting, and reading posts on this site and the EFV8 site, led me to the problem. A previous owner had installed a Hella 6V flasher, which I changed out for a 535 6V flasher, and the indicator now works. Don't ask me what the difference is in the two flashers. One other thing I did, because I can't hear the little click of the flasher at my age, was to install a small 6V buzzer up under the dash. I went to ground with one lead, and the blue (on my unit) wire for the power. It works great, but I had to put tape over 2/3 of the buzzer opening, as it was a bit too loud.
51woodie is offline   Reply With Quote
Old 04-15-2021, 10:03 AM   #3
FortyNiner
FortyNiner's Avatar
I'm running Signal Stats on both of my old vehicles . The indicator light works on one but not the other. I attributed the non operational version to the 'as-is' seller description. The units have otherwise been flawless.
19 and 49 F1 - jes' like Henry II built
1946 Deluxe - as Henry built it
FortyNiner is offline   Reply With Quote
Old 04-15-2021, 10:19 AM   #4
Lawson Cox
Lawson Cox's Avatar
10/4 on the buzzer/beeper being too loud. Does anyone know of a similar "clicker" type gizmo?
Old 04-15-2021, 10:36 AM   #5
51woodie
51woodie's Avatar
FourtyNiner. The indicator light quit working on mine after a while, so I opened the switch body to see if I could change the bulb. What I found was the wire that is connected to the indicator light socket had broken off. The reason is, that the wire flexes every time the signal lever is moved between positions. I re-soldered the wire and problem solved.
Lawson. Just add more tape.
Old 04-15-2021, 11:08 AM   #6
FortyNiner
FortyNiner's Avatar
Thanks for the tip. I'll put it on my 'maybe' list.
Old 04-15-2021, 12:59 PM   #7
TJ
TJ's Avatar
The broken wire to the indicator light seems to be a common problem with the 900. I put a green LED light in the dash and wired direct to the flasher. Much easier to see as the steering wheel can block the indicator light in the signal unit.
Old 04-15-2021, 03:40 PM   #8
JSeery
JSeery's Avatar
That's what I do, except use an old time crystal cut lens on the light. Found some LED bulbs that fit the sockets.
Old 04-16-2021, 11:42 AM   #9
corvette8n
corvette8n's Avatar
This buzzer it what I put on my ‘41, had to cover the hole with a piece of tape as it was too annoying.
File Type: jpg E3C019BC-ADA7-4EDB-93A8-6DD318570A03.jpg (30.8 KB, 16 views)
Old 04-16-2021, 12:44 PM   #10
1948F-1Pickup
1948F-1Pickup's Avatar
I’ve got a 900 series on my truck. Initially dismayed about the indicator light as it either didn’t work at all or they didn’t flash...... I can’t remember which. I changed out the original flasher unit when it failed for the heavy duty part number. The indicators work fine now.
EL13 is the HD flasher I used.
1948F-1Pickup is offline   Reply With Quote
Old 04-18-2021, 03:20 AM   #11
Graeme / New Zealand
Graeme / New Zealand's Avatar
My 48 NZ assembled car carries a RHD version of the US 41 Dash (all NZ assembled 46 -48 Fords used this dash). I use a Signal Stat 900. I don't have a radio so mounted the flasher unit which is a 6v Tridon type behind the speaker grill, using one of those tubular sprung metal clips, this is plenty loud enough.
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
Old 04-18-2021, 07:17 PM   #12
drolston
drolston's Avatar
I have the same type turn signal and again the indicator quit after a short time. I will check inside to see if I have the same broken wire issue.
I used this beep flasher which is just loud enough.
https://www.ebay.com/itm/Turn-Signal...4AAOSwCm9gWPCD
Old 04-19-2021, 03:09 PM   #13
slowforty
slowforty's Avatar
Make sure your turn signal bulbs are large enough to make the Flasher operate.
Drove me nuts trying to figure the problem out.
slowforty is offline   Reply With Quote
