Old 04-10-2021, 03:37 PM   #1
flathead48
Default 6-12 volt
I am thinking about converting my 6 volt ford to 12, I was told that ford continued on with 6 volt gauges after going to 12 volts. Can anyone give me a part number or description of the reducer they used. Thanks
flathead48 is offline   Reply With Quote
Old 04-10-2021, 03:51 PM   #2
dmsfrr
dmsfrr's Avatar
Default Re: 6-12 volt
Here's a link that should give you some good info and answer a few of your questions.
Yes it was written for '55 T-Bird owners but 99% of it should apply to most any 6 volt Ford.
https://www.ctci.org/battery-for-6v-to-12v-conversion/
Assuming the car has the old/original King-Seeley brand gauges... they function differently than '57+ gauges and should Not need a voltage reducer. They work on current flow and heat generated in a switching circuit, not voltage and variable resistance, so they are effectively self-regulating.
They are also not polarity sensitive.
Yes the '57+ gauge circuits use a regulator for approx 6 volts, but the gauges & sensors are also built with different electrical specs and aren't usually compatible when mixed with original 6 volt parts.
FYI, gauges and sensors in '56 Ford products are one-year-only and were designed for full 12 volts.
File Type: jpg 'King Seeley' fuel gauge diagram '55.jpg (72.2 KB, 16 views)
dmsfrr is offline   Reply With Quote
Old 04-10-2021, 03:55 PM   #3
55blacktie
I converted my 55 T-bird to 12v. There was no need to convert gauges or sending units to 12v, and they seem to be working as well as ever. However, you must use 6v senders with 6v gauges, and 12v senders with 12v gauges. Don't mix the two.
55blacktie is offline   Reply With Quote
Old 04-10-2021, 06:08 PM   #4
flathead48
Thanks guys, appreciate the great info
Old 04-10-2021, 06:15 PM   #5
darrell
a friend converted his 54 and used a 12 volt coil with built in resister.has no problems
darrell is offline   Reply With Quote
Old 04-12-2021, 12:13 PM   #6
JMFL36
JMFL36's Avatar
I have 3 gauge reducers, 12V flasher, horn relay, solenoid, and a bunch of 12V bulbs. Willing to trade for your 6V stuff.
Document your car with CollectorCarCompanion
JMFL36 is offline   Reply With Quote
Old 04-12-2021, 02:07 PM   #7
JeffB2
JeffB2's Avatar
Step # 13 here: https://darksidersrealm.forumotion.c...egative-ground This is what you need: https://www.classicindustries.com/pr...MaApLMEALw_wcB
JeffB2 is offline   Reply With Quote
Old 04-12-2021, 02:10 PM   #8
JeffB2
JeffB2's Avatar
Originally Posted by JeffB2 View Post
This shows how it's wired in you only need one regulator. You do not want to hook up the AMP gauge if you now have an Alternator you'll need a volt meter in it's place.
Old 04-12-2021, 02:14 PM   #9
JeffB2
JeffB2's Avatar
The "gauge reducers" (aka Runtz) do not work with 50's Fords King/Seely gauges however they can be used for other light load accessories.
Old 04-12-2021, 02:59 PM   #10
55blacktie
I converted my dad's 55 T-bird to 12v because he said it was hard to start. He was very pleased with the conversion, saying it had never cranked over so easily before. Unfortunately, he didn't last too long after that. I followed Gil Baumgartner's (CTCI/Gil's Garage) instructions when doing the conversion.
Old 04-15-2021, 08:56 AM   #11
flathead48
Thanks to all. Happy motoring
Old 04-15-2021, 02:40 PM   #12
Herman Munster
Herman Munster's Avatar
The most common issue I've seen with problematic 6v starting systems is wrong sized battery and ground cables. You can't use the same gauged cables on a 6v system as you do on a 12v. 6v cables are quite a bit larger in diameter.
1956 Ford Fairlane Town Sedan 292 V8 with Ford-o-Matic
Herman Munster is offline   Reply With Quote
Old 04-15-2021, 03:32 PM   #13
55blacktie
6v probably fine for low-compression flathead. OHV engines have higher compression, needing more cranking power. Ford continued 6v through 55, switching over to 12v in 56 (wonder why?). Okay to use 6v cables/w 12v battery. That other brand went to 12v in 55, pretty much for the same reason Ford did in 56.
Old 04-15-2021, 06:08 PM   #14
Gene F
Gene F's Avatar
I have heard what Herman say many times. Problem is that the big cables are getting hard to find. I wonder if a trucking garage has big cable that they make up?
Gene F is offline   Reply With Quote
Old 04-16-2021, 07:12 AM   #15
Daddio
Daddio's Avatar
You could fab a cable using wire from a mig welder. These cables are also much more flexible, due to the multiple internal strands.
Daddio is offline   Reply With Quote
Old 04-16-2021, 09:39 AM   #16
KULTULZ
KULTULZ's Avatar
Post Re: 6-12 volt
Maybe give this a read - https://www.custombatterycables.com/
- WHY IS IT ... -
... that everything you buy in the grocery store is either wrapped in or contained in plastic but the government doesn't want you to carry it out in a plastic bag?
WONDERING IN W(BY GOD)V ...
DIAGNOSED CDO - (OCD In Correct Alphabetical Order)
KULTULZ is offline   Reply With Quote
Old 04-16-2021, 10:37 AM   #17
dmsfrr
dmsfrr's Avatar
Corrosion, a bad connection or the wrong sized Ground cables can affect the electrical system just like a bad connection anywhere else, but they get overlooked for some reason.
Originally Posted by Gene F View Post
... Problem is that the big cables are getting hard to find. I wonder if a trucking garage has big cable that they make up?
Welding cable can be used. When a long length has some damage in a small-ish spot it could make several cars worth of replacements.
The T-bird shops that do restorations have large "0" gauge cables for the 55's and may be able to make up cables in a requested length.
Shoebox Central seems to have cables available also...
https://shoebox-central.com/battery-4
Old 04-17-2021, 04:42 PM   #18
Herman Munster
I think it's still easier and cheaper to find the right cables than looking for and ordering all the resistors, bulbs and upgrading the generator or buying an alternator and then doing all the work to swap/install the parts.
A 6v starter only sounds slow and weak but will start a stock V8 fine. I had a '51 Cadillac with a 331 V8 that was 6V and started easily. A lot of car makers actually went to 12V because of all the electrical accessories that were becoming popular during to 50's. 12V also did make starting high compression engines a lot better. 6V will still start an engine with 8.5 to 1 compression reliably like in the 55 T-Bird with 292 and automatic.
Old 04-17-2021, 05:42 PM   #19
55blacktie
Being an owner of a 55 T-bird that I converted from 6v to 12v, if 6v had been fine, I would not have converted to 12v.
Old 04-17-2021, 07:41 PM   #20
paul2748
paul2748's Avatar
This is what Ford used starting with 1957 - the one below is a later unit, but is the same in utilization - Instrument Voltage Regulator. These should be available at NAPA or some one like Dennis carpenter
48 Ford Conv
56 Tbird
54 Ford Victoria
