03-16-2021, 01:52 PM | #1 |
brake return spring ??
Hi guys, brake pedal doesn't want want to return all the way. So i bought a return spring from brattons. I know its after market but i figured i'd give it a try. it comes with a spring and a metal hook but no instructions on how its installed, any one ever put one in there car. its a 31 roadster. I tried to post a pic. of what i have but no luck doing that either. thanks THE HOOCH
03-16-2021, 02:12 PM | #2 |
Re: brake return spring ??
I don't have it on my car, it returns fine, but have seen one that hooks over the pedal arm and hangs down, with spring connected to motor mount hole
What condition are your anti rattle springs? |
03-16-2021, 02:29 PM | #3 |
the heavy metal bracket wraps around the brake pedal, and the coil spring hooks to that bracket on one end and the motor mount on the other.
click here to see a diagram https://www.brattons.com/files/index...id/1497547036/ |
03-16-2021, 04:20 PM | #4 | |
03-16-2021, 06:27 PM | #5 |
I had one at one time. It was fine. Just didn't need it, so once when I was working on the car I did not put it back on.
03-16-2021, 06:31 PM | #6 |
03-17-2021, 06:22 AM | #7 |
When I bought my A the brake peddle would not fully return and the brake light stayed on. I installed the return spring from Brattons and and peddle returns all the way and brake light goes off.
03-17-2021, 01:08 PM | #8 |
I used one also. Returned the pedal great, but I found that actually fixing the problem worked great as well. Replaced bushings in brake and clutch pedals, new brake rods and anti-rattlers. inexpensive fixes that eliminated the need for the return spring
03-17-2021, 04:37 PM | #9 |
Imagine that! Fixing the problem actually fixing the problem. Without the need of additional parts (Bandaids?). Good job, twilder!
The Master Cylinder Enjoying life at the beach in SoCal... Last edited by The Master Cylinder; 03-17-2021 at 06:38 PM. |
03-17-2021, 09:59 PM | #10 |
By a spring from your hardware store and fabricate your own brackets
03-18-2021, 05:20 PM | #11 |
But if we fix it the “correct way”. What will we “fix” next weekend?
Good things take time |
