Old 01-23-2021, 01:13 PM   #1
ericr
ericr's Avatar
Default What is Easiest Way to Install Instrument Panel Components??
what order do you guys use that is easiest to reconnection things in the panel to re-install it? it's a tight fight at best, the Electrolock and speedometer
apparently have a certain order to reconnect the easiest, what would that order be?
ericr is offline   Reply With Quote
Old 01-23-2021, 01:59 PM   #2
Big hammer
Default Re: What is Easiest Way to Install Instrument Panel Components??
Switch first, wires second, speedo cable last, start the two lower screws and then the middle screws. Fighting the dash light wire, speedo cable, and switch cable is a PAIN ! Make sure not to pinch wires !
get a bigger hammer tap done
Old 01-23-2021, 04:01 PM   #3
vern hodgson
Tip the lower part in making sure the speedo is in side the mounting flange, other wise you will really fight the top to fit.
vern hodgson is offline   Reply With Quote
