Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 08-01-2020, 02:14 PM   #1
DKnapp
Default Model "B" Motor
City: Garfield
State: Arkansas
Price: in ad
really nice "B" block. I have examined this block closely and could not see any cracks the "B" blocks usually have. There is surface rust on the 4" bores, but they may clean up with honing. The mains look really good and they measure 1.977".
The crankshaft mains measure 1.984" and the rod journals 1.852". The 4 "B" rods measure 1.870". Also included is "B" Timing cover, "B" intake manifold, "B" carburetor, "B" exhaust or "A" exhaust (your choice), used clutch, "B" flywheel, pressure plate, side valve cover, alum. fan (has chip in pulley), oil pump/dist. drive, oil pump, "B" water pump, "B" cam and "B" oil pan. I do not have a "B" flywheel housing or "B" head. I can include an "A" flywheel housing.
Heavy load, prefer pickup in NW Arkansas (between Bentonville and Eureka Springs). Shipping would require 2 or 3 crates. I'm willing to crate for a couple hours labor($20) and material expenses, then deliver to your choice of shipper.
$1500 + crating + shipping.
Dick Knapp, [email protected] 479-586-0070
DKnapp is offline   Reply With Quote
Old 08-17-2020, 09:50 PM   #2
DKnapp
Default Re: Model "B" Motor
Better check this again guys. Look at all you are getting for less than the price of a new counter balanced crankshaft. Will consider parting this lot out piece by piece. Let me know what you are interested in.
Thread Tools
Display Modes
