Old 06-21-2020, 01:28 PM   #1
shoe box Jack
Default rear gear 3.08-1
HI guys, I'm thingking about changing the gear in the 49 car from a 3.78 to a 3,o8 hoping it would make the car more hyw. friendly ?. thanks for any info. Jack.
shoe box Jack is offline   Reply With Quote
Old 06-21-2020, 03:22 PM   #2
Fordestes
Default Re: rear gear 3.08-1
If you are using an automatic trans mabe you will be ok , I tried the very same gear ratio with a 3 speed box and I constantly had to stay in the box ( constantly downshifting) even on flatland, and my fuel mileage went to hell also, I went back to a 3.55.
Fordestes is offline   Reply With Quote
Old 06-21-2020, 04:18 PM   #3
shoe box Jack
thanks for the reply Fordester it has a 3 peed trans. I should take a look at a 3.55 so far I;m shopping for the best hwy. gear. Jack
Old 06-21-2020, 04:19 PM   #4
JSeery
JSeery's Avatar
That's a fairly heavy car for that high a gear isn't it?
Old 06-21-2020, 05:55 PM   #5
KGS
KGS's Avatar
Unless someone has changed your rear gear, you should
have a 3.73 to 1 gear ratio. Why not look around for an
over drive trans. The reduction will be about 30%. If your
ultimate aim is to go "Faster", remember, your should upgrade
your brakes to go along with the extra speed.
Ken
KGS is offline   Reply With Quote
