Old 04-03-2020, 12:21 PM   #1
Jwilli
Jwilli's Avatar
Default Reason to use distributor condenser hole plug.
No voltage to points. Looks like some insect had a good home for the winter.
Jwilli is offline   Reply With Quote
Old 04-03-2020, 02:36 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Reason to use distributor condenser hole plug.
Wow! Never seen anything like that~!
www.whidbeymodelaclub.com
Old 04-03-2020, 02:43 PM   #3
1931 flamingo
1931 flamingo's Avatar
What's your upholstery look like??
Paul in CT
Old 04-03-2020, 03:39 PM   #4
Brentwood Bob
Just a little detritus....
Brentwood Bob is online now   Reply With Quote
Old 04-03-2020, 03:42 PM   #5
Jim/GA
Jim/GA's Avatar
Yellowjacket nest?
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 04-03-2020, 05:28 PM   #6
Jwilli
Jwilli's Avatar
1931 Flamingo, this is my Anna Mobile. I built it from a trailer load of parts. The Beverly Hillbillies truck was my inspiration. It does not have any upholstery.
Old 04-03-2020, 05:53 PM   #7
30 Closed Cab PU
Nice.
What is what looks like a tree limb slingshot on the back for?
30 Closed Cab PU is offline   Reply With Quote
Old 04-03-2020, 05:58 PM   #8
Jwilli
Jwilli's Avatar
Originally Posted by 30 Closed Cab PU View Post
Nice.
Every vehicle needs to be armed these days.
Old 04-04-2020, 04:02 AM   #9
Bruce of MN
Bruce of MN's Avatar
That would look much better with Model A wheels.
Bruce of MN is offline   Reply With Quote
Old 04-04-2020, 04:22 PM   #10
Jwilli
Jwilli's Avatar
Distributor all cleaned and reinstalled. Engine runs but clutch is stuck. With engine off, it will shift into all gears. With engine running it grinds when trying to shift to any of the 4. Suggestions for the best way to get clutch to release would be appreciated.
Old 04-04-2020, 05:45 PM   #11
Will Ziegler in LI NY
Will Ziegler in LI NY's Avatar
Make sure you have some space in front of you, then start it in gear, get it moving, step on the clutch and then hit the brakes. That is how I have unstuck mine.
Will Ziegler in LI NY is offline   Reply With Quote
Old 04-04-2020, 05:59 PM   #12
Jwilli
Jwilli's Avatar
Will that work in reverse? It is in the garage at the top of the hill. I can only go backward for about 50 feet before being able to turn.
Old 04-04-2020, 06:33 PM   #13
Jim/GA
Jim/GA's Avatar
Please start a new thread with this stuck clutch problem in the title, to help others find the discussion in the future.
Jim Cannon
