Old 01-07-2020, 10:03 AM   #1
rer_239
rer_239's Avatar
Default Steering box
Questions: Les Andrews mentioned lubriplate for assembly, is that like assembly lube? Also is there an alternative to 600 weight lube?
Thanks
Dick
rer_239 is offline   Reply With Quote
Old 01-07-2020, 11:27 AM   #2
David R.
Default Re: Steering box
Yes lubriplate, like you would use assembling an engine. Several manufacturers make a modern equivalent to the 600w. (They used to call it steam cylinder oil) You likely won’t find it in your local auto parts store. If you have a commercial distributor they can get it but I think you have to buy 5 gallons. Most all the A suppliers sell it by the quart for 8 or 9 bucks. The 5 gallons probably cost you $100.
David R. is offline   Reply With Quote
Old 01-07-2020, 11:49 AM   #3
katy
katy's Avatar
Any light grease will work for assembly, chassis grease, vaseline, etc.
Old 01-07-2020, 12:49 PM   #4
Werner
Werner's Avatar
Originally Posted by rer_239 View Post
... Also is there an alternative to 600 weight lube?
Hallo Dick,
you can use 680 industry machinery oil.
Beste Gruesse aus Deutschland,
Werner
Ford Model A, Roadster, 1928
Citroen 11 CV, 1947
Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version
Werner is offline   Reply With Quote
Old 01-11-2020, 08:06 PM   #5
rer_239
rer_239's Avatar
Hey thanks for the info
Dick
Old 01-12-2020, 10:35 AM   #6
1931 flamingo
1931 flamingo's Avatar
PennRite steering box lube...........NO leakee
Paul in CT
Old 01-12-2020, 10:47 AM   #7
Ranchero50
I did a mix of grease and gear oil in mine yesterday. Installed the light rod tube versus seal as well.
Had to replace the column as it was cracked. Good times.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
