03-25-2018, 12:10 AM | #41 |
Re: 8RT pulling the heads
I also am a fan of home shop overhauls. Looks like you have everything covered and am glad to see a neighbor just across the sound going at it the way you are. I would be interested in that crash box 4 speed if it needs a home. Lots of V8 and truck stuff over here for trades if you end up needing parts.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
03-25-2018, 03:17 PM | #42 |
Ron, when I bought the truck not only did the accelerator pump not work, but the linkage to it was missing. Idle mixtures were really rich, I'm sure to help compensate for the lack of the pump. One of the first things I did was to rebuild the Holley 94. Double clutching without an accelerator pump is nearly impossible! It has #51 jets, I figure once I get it running better and can dial in the jets if need be.
After I got the carb working, got all the proper pulleys and belts installed, pulled the rats nest of wiring out and made a simple harness with enough to start and run the engine, charge the battery, and run the brake lights I got to go for a drive! https://www.youtube.com/watch?v=oZZny4uzBs8
"whatever works!" |
03-25-2018, 03:42 PM | #43 |
GB SISSON, we are probably only about 20 miles away from one another as the crow flys! This old 4 speed is now officially yours! The only thing I'll miss is the whine... classic old truck sound. I think the tranny is in good shape, the shifter seems sloppy though. The drive-line is yours too if you want it, won't work with the lite duty three-speed. I've got a NOS slip-joint and guess I'll have to have a drive-line made. About the only things I'm looking for at this time is a transmission cover (mine's all rusted out!) and a 6 volt generator so I can convert it back to 6 volt positive ground. Regardless, you can have the transmission.
I'm of the mind set now to do as little "evasive" work to these old engines as possible and still get a good runner. My original intention with my 30 coupe was to pick up an engine in good enough shape to get me by while I had the other professionally rebuilt. I went through the 2nd engine, cleaned it up good, new rings and hone job, and lapped valves as needed. I scored a nice Brummfield 5.9 head and she's running great. With my confidence built up I've looked over my original engine and other that the cam being pretty worn I think it is pretty salvageable the way it is. I'm really looking forward to getting the F1 back on the road for the summer.
"whatever works!" |
03-27-2018, 02:31 PM | #44 |
The crank is out and things look pretty good. Main bearings are -.020 and clearance is .0015-.0020, if the thrust bearing wasn't so worn, they could probably be re-used. Timing gears look very good too, things are looking promising. Checked the valve lash too as a go no-go with min and max feeler gauges, all are within spec/range but I'll go dial them in later. Found blue paint under the flaking red. Lots of cleanup to do then I'll look at the valves.
"whatever works!" |
04-03-2018, 10:08 AM | #45 |
Things have come to a screeching halt.
I've found two cracks from exhaust to cylinders... drat. Strange that I wasn't experiencing any water in the crankcase, that I could detect anyway.
"whatever works!" |
04-03-2018, 10:32 AM | #46 |
04-03-2018, 10:53 AM | #47 |
I guess it's a "what do I have to lose" scenario.
"whatever works!" |
04-03-2018, 11:14 AM | #48 |
I'm with you, my friend. Unless you have a Merc crank, all of the internal parts are cheap and easy to find if it blows up. It'll probably go another 40,000 miles with a "home shop overhaul", though. Also, the "Irontite" thread seems to show that there are multiple miracle block sealers out there.
04-07-2018, 08:27 PM | #49 |
I've been putting in a few hours a day on my "red-neck" rebuild. I have all the valves on the LHS loose. I've released the keepers and the guides are still in place. I've done a little "lapping" on them to see if it will even be feasible to clean them up without machine work. Most are very good, one is a little rough and one is down-right nasty. I have been in contact with a local machinist that speaks "flathead" and will have him take a look at the cracks and see what he thinks.
"whatever works!" |
04-07-2018, 08:37 PM | #50 |
Looking good. I like your style.
My 36 was popping and couldn't even drive it on the trailer when I bought it, some timing issues too. 95 across the board but one cyc at 30 (surprising it was that much). Heads off and found a burnt valve. A kind gentlemen here sold me a very nice used valve assembly for 7$. Lapped. Been driving it for 4yrs now, solid compression. Not a daily driver mind you, but I drive it as much as I can. Enjoying your progress! Last edited by Tinker; 04-07-2018 at 08:43 PM. |
04-07-2018, 08:57 PM | #51 |
Anyway you look at it, it will be better than it was! I figure at the least it's a great learning experience. A Model A buddy of mine tells me he has a flathead seat grinding setup, I might need to go get it and test it for him. 8^)
"whatever works!" |
04-07-2018, 08:58 PM | #52 |
BTW, there are seats in every hole so it must be a older engine. I suppose it's possible it's the original but have no idea really
"whatever works!" |
04-12-2018, 05:32 PM | #53 |
I bought this el-cheapo valve spring compressor from Amazon, works well on this engine.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
"whatever works!" |
04-25-2018, 11:31 PM | #54 |
Plans have changed a bit.
Found a nice engine locally, bought the stand and all. Looks like it has all necessary parts to go in my F1 except for the oil pan. Even the clutch looks correct but I need to pull it out and take a look.
"whatever works!" |
04-26-2018, 05:27 AM | #55 |
Nice score . Good to see some are still out there
04-26-2018, 08:03 AM | #56 |
Nice find!
04-26-2018, 08:43 AM | #57 |
I'm enjoying working on these engines and now I'll have the test stand to run them on. The fellow I bought it from has quite a collection of extremely nice autos, and now he is thinning the herd. He has owned it for 6 years and has only fired it up a time or two for people to hear it run. The gas is old but it still started up easily.
https://www.youtube.com/watch?v=ItCXe0zqwgc
"whatever works!" |
04-26-2018, 11:11 AM | #58 |
If you do more than one or two engines in your life, you'll really appreciate having a test stand. I built mine about 4 years ago to test run an early hemi I found, and since have had two flatheads on it. Next up is my '51 Olds Rocket. I built mine with the mounting part of one of those cheap 3-wheeled engine stands at the rear so I can easily mount most types of engines.
04-26-2018, 11:26 AM | #59 |
Built a simple storage stand for my Model A engine, ended up running it on it before I installed it in the car.
https://www.youtube.com/watch?v=UABtaPsSZ0Q
"whatever works!" Last edited by Art Newland; 04-26-2018 at 03:27 PM. |
04-26-2018, 03:24 PM | #60 |
GB SISSON, We'll have to hook up someday. Crashbox is out!
"whatever works!" |
