Old 06-06-2015, 11:11 AM   #1
Floats
Floats's Avatar
Default Another U Joint question
Hi Guys,
Could anyone pse ID the U joint, in the attached pictures, which I found slap in the middle of my Pickup.
Regards
Chris
Floats is offline   Reply With Quote
Old 06-06-2015, 11:31 AM   #2
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Default Re: Another U Joint question
what pictures??
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 06-06-2015, 01:06 PM   #3
Floats
Floats's Avatar
Sorry,
Old 06-06-2015, 01:07 PM   #4
Floats
Floats's Avatar
One more,
Old 06-06-2015, 02:29 PM   #5
J Franklin
J Franklin's Avatar
Model A.
Old 06-06-2015, 10:19 PM   #6
Floats
Floats's Avatar
The U joints available from the vendors is different from mine. The new pedal shaft and bushes are also different and much thinner. Is it possible that I have an early AR car. It is registered as a 1928, but who knows?
Regards
Chris
Old 06-06-2015, 11:16 PM   #7
J Franklin
J Franklin's Avatar
The vendors sell a more modern ford U-joint used thru 1948, the one you show was factory for the model A. You could be driving an early car what is the serial #?
Old 06-06-2015, 11:58 PM   #8
Tanglfoot
Pedal shafts were made one inch for the RH drive cars and 3/4 for LH don't know why. I made mine from 1 inch stock and used big end (wrist pin) bushes
Ahooga, Rosco.
Tanglfoot is offline   Reply With Quote
Old 06-07-2015, 02:11 AM   #9
Floats
Floats's Avatar
Tks J,
I believe mine was built from parts and I do not have the serial number because I never saw the frame and it might not even have the same engine number. But thanks anyway. The engine is at the engineering works at the moment.
Regards
TKS Roscoe,
Funny enough the LH/ RHD came to mind but I thought NAA NEVER, CANT BE.
Thanks for the tip.
Regards
Chris
Cape Town
Old 06-07-2015, 03:22 AM   #10
leakers
Les Pearson has written a book on the right hand drive model A , he used to manufacture most of the parts, but has sold the business now and retired to write about Model As.
Selling his book on Trademe ( a local version of Ebay)
http://www.trademe.co.nz/Browse/List...x?id=897509976
also available from Amazon and Model A dealers
or you can see his book and his contact details on Youtube
https://www.youtube.com/watch?v=CRFtCeGXwOw
He has written other books too.
He sold the parts business to these guys.
http://www.earlyfordparts.co.nz
http://www.earlyfordparts.co.nz/right_hand_drive.htm
leakers is offline   Reply With Quote
Old 06-07-2015, 04:52 AM   #11
Floats
Floats's Avatar
Tks for the heads up, Leakers, I'll have a look.
Chris
Old 06-07-2015, 11:35 AM   #12
Floats
Floats's Avatar
Forever 4,
Please read my post #6 then you will know what the 'spam' is all about
Old 06-08-2015, 07:15 PM   #13
Floats
Floats's Avatar
It seems as if U joints have been out of stock for more than a year now. Any one know of a vender that might have, please. Or suggestions for a substitute unit.
Regards
Chris
Old 06-08-2015, 08:22 PM   #14
J Franklin
J Franklin's Avatar
Some are listed on Ford barn swap section. What is wrong with the one you have?
Old 06-09-2015, 12:01 AM   #15
leakers
Originally Posted by forever4 View Post
What is with all the non related spam?
U joints don't come in RHD and LHD versions!
But you already knew that.
How do you know that U joints are not different in the RHD cars?
I have nothing to do with Mr Pearson other than that I have purchased parts from him.
My intention was simply to share information, just as your website does sir.
May I ask,
Why do you list your website at the bottom of every post you make?
Old 06-09-2015, 12:56 AM   #16
Floats
Floats's Avatar
J,
Mine still seems good and solid BUT the front part is cracked. It looks as if there is a washer between the gearbox output shaft and the front section of the U Joint which was not insetred correctly. I think the washer was sitting at an angle when the bolt was thightened, which caused the housing to crack.
Apparently the vendors hadnt had any for a year. I suppose it could be welded up until I can get a new one. It is such a hugh job to replace it at a later stage, so I was hoping there was a later model I could use.
Regards
Chris
Edited. In fact if you look closely at my first picture the one in post #3 you can see the crack where the through bolt tightens down.
Old 06-09-2015, 01:16 AM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
Originally Posted by Floats View Post
J,
I think you are seeing a cracked washer. Try tapping it out of the U-joint.
Old 06-09-2015, 02:13 AM   #18
Floats
Floats's Avatar
Hey Tom, you are correct. I thought it was part of the casting. I pried it off and the U joint is fine but the washer is cracked.
Thank you very much Tom. I am good to go.
And thanks every one for your input.
Regards
Happy Chris
Cape Town
Old 06-09-2015, 05:20 AM   #19
Tom Wesenberg
That's a special thick washer with a tab to fit between the splines.
Do you have a spare, or can you order one?
