Old 04-17-2021, 08:10 AM   #1
Bob/AZ
Bob/AZ's Avatar
Default Mixed Signals
I have one of those Signal Stat 900 universal turn signal switches. I have blown 10 inline fuses trying to trace the problem of blowing the fuse when the left turn signal is turned on. It works fine on the right signal. I have inspected all the wiring associated with it in great detail, even cut all the zip ties attaching it to the frame, etc. and pulled the wire away. Fuses still blow. Bulb sockets are like new and I see no problem inside any of the after market signal lights.
I am wondering if the problem might be in the switch itself and if anyone has seen a problem like this with the Signal Stat. Any ideas welcome! Bob
Bob/AZ is offline   Reply With Quote
Old 04-17-2021, 08:22 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Mixed Signals
I've not had an issue with the Signalstats.
You might need/want to cut the wire in question coming from the switch just to try and locate the problem. If that wire is cut from the switch and the fuse then blows it'll probably be a switch issue. If it doesn't blow then the problem is somewhere down stream to one the lights. It seems like there is a ground/short somewhere.
Old 04-17-2021, 09:57 AM   #3
GRutter
GRutter's Avatar
You might try taking the SignalStat wire feeding the right and left sides and swap them, that is, turn the SignalStat like you are turning Left to make the Right turn signals illuminate.
If the problem repeats with the SignalStat turning left, then the problem is in the switch.
If the problem repeats with the SignalStat turning right (to illuminate the left lamps) then the problem is in wiring / bulb sockets on the left side.
GRutter is offline   Reply With Quote
Old 04-17-2021, 05:49 PM   #4
Bob/AZ
Bob/AZ's Avatar
Thanks, still working on it , no joy yet.
Old 04-18-2021, 06:47 AM   #5
macdonge
macdonge's Avatar
I had a similar issue. Check out the thread below to see what I discovered was the cause:
https://www.fordbarn.com/forum/showthread.php?t=242551
macdonge is offline   Reply With Quote
