Old 09-13-2020, 04:57 PM   #1
dorvedahl47pu
dorvedahl47pu's Avatar
Default 47 Ford Pickup Windshield Replacement
Does anyone out there who has replaced a 40-47 Ford pickup windshield know if it a good idea to use a sealant in addition to the new rubber seals?
Thanks in advance.
dorvedahl47pu is offline   Reply With Quote
Old 09-13-2020, 05:15 PM   #2
alanwoodieman
Default Re: 47 Ford Pickup Windshield Replacement
most trouble I have had with these is leaking around where the seals overlap in the center and ends where the outside trim piece fits
Old 09-13-2020, 05:17 PM   #3
Fordestes
I always use a windshield sealant, the stuff I use is from 3- m, I didn't use it once and regretted it, the water seeped around the bottom onto the dash and started to rust a bit before I realized what was happening.
Fordestes is offline   Reply With Quote
Old 09-13-2020, 06:17 PM   #4
dorvedahl47pu
Thanks...very helpful!
Old 09-13-2020, 08:28 PM   #5
A bones
A bones's Avatar
Avoid using silicone. It will promote rust. ( one of my inventory )
The prefered sealant is polyurethane. Please disregard.
I am wrong. (once more) This info (Urethane) was from someone else. I was impressed because of my experience with silicone. So having checked with youtube, I see it is for glue set cars. Not gasket set. (Seen both done in my days of repair work.)
My apologies. Difficult tho it is I say, I shall only post when I need help with my own project.
Enjoy yer day. Tom
Hate can't fix what it started.
Last edited by A bones; 09-14-2020 at 10:50 PM. Reason: wrong info Time to Bow Out
A bones is offline   Reply With Quote
Old 09-13-2020, 09:26 PM   #6
GB SISSON
GB SISSON's Avatar
Timely... The glass for my '47 pickup windshield came in last week. Now I gotta find a youtube video about replacing it!
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
GB SISSON is online now   Reply With Quote
Old 09-14-2020, 01:37 PM   #7
dorvedahl47pu
Could you explain how to seal with the polyurethane please? I assume you "paint" it on the exterior of the seal after installation?
Thanks.
Old 09-14-2020, 11:13 PM   #8
A bones
A bones's Avatar
Thanks.
First, may I say Welcome to The Barn. Please read my edited post #5.
You can have my place here. I am no longer fit to be a part of this wonderful project ( flathead education enjoyment )
Unlike me, the steady contributors here are priceless. I wish You the best ( lotsa fun ) with your truck. I thank all who have kept me afloat. Still I shall lurk as I am hungry to get on my feet, and make this more than a wish.
Enjoy yer day. Tom
Old 09-16-2020, 11:25 PM   #9
dorvedahl47pu
No worries at all! If only people who have never been wrong posted, this forum wouldn't be worth much, so it's ALL GOOD!
Old 09-19-2020, 08:41 PM   #10
1oldtimer
1oldtimer's Avatar
I used the 3m stuff which works good but harder to clean up and is thicker (harder to put under rubber lip). I used some cheap black gasket sealer from Orileys on my panel truck and it was easier to clean up, easier to apply under the seal and is waterproof......only thing to find out is how long it will last (1 year and counting). I'm going to try it on my '41 p/u.
One piece of advice I can give is to make sure all rust is gone on the pinchweld (or use a rust treatment like POR15) and it's sealed (painted) before you put the windshield back it. I was inpatient, put mine in after just wiping down the pinchweld and installing the glass. You could see that is was painted with the window in place AND the exposed area started to get surface rust . So I get to do it again, the right way this time.
Also take your time and use lots of lube (soap), the gasket will try to crease or tear in the top outside corners.
1oldtimer is offline   Reply With Quote
