Old 07-19-2020, 05:49 PM   #1
rer_239
rer_239's Avatar
Default Sub-rail extension s
Anyone know if the sub-rail extensions (i.e. the pair listed in a parts catalog #A-132-EXA) fit a '29 Murray cowl?
rer_239 is offline   Reply With Quote
Old 07-20-2020, 11:29 AM   #2
1929
Default Re: Sub-rail extension s
I replaced all my rails for my 1929 Special, I bought the set from Brookville roadster.
1929 is offline   Reply With Quote
Old 07-20-2020, 12:14 PM   #3
rotorwrench
rotorwrench's Avatar
29 Murray is kind of a broad group since Murray made several bodies for Ford. The Murray and Briggs cowls were very much alike but they used a lot of wood and generally, the sub rails were also wood. The steel sub rail extensions were used on all the cars that had steel sub rails or body sill. (whatever term a person wants to use) I'm not so sure about the wood framed cars like the different fordor bodies and the cabriolet. They probably did use them but I don't know if they are exactly the same. If Ford supplied them to the sub contractors, they would most likely be the same.
Old 07-20-2020, 05:52 PM   #4
rer_239
rer_239's Avatar
That makes sense.
Thanks
Dick
