04-16-2020, 04:38 AM | #1 |
Soldering
What type of solder should be used for electrical wiring
Thanks Dick |
04-16-2020, 06:33 AM | #2 |
Re: Soldering
Any good solder as long as it is not meant for plumbing. I use this stuff:
https://www.amazon.com/Solder-Sn99-3.../dp/B072WP4H99 It is a lead free solder so it is safer than the older stuff. It is mostly tin, hence why it is said to "tin" a wire. It is easy to work with, almost too thin. Never have had a problem with it.
"The more things change, the more they stay the same." |
04-16-2020, 06:34 AM | #3 |
Re: Soldering
Rosen core solder
04-16-2020, 06:39 AM | #4 |
Re: Soldering
Rosin core for electrical. Acid core is used for plumbing. Lead or lead-free will work. Lead-free has a slightly higher melting temperature.
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive 1935 Model 48 Tudor |
04-16-2020, 08:38 AM | #5 |
Re: Soldering
Most common (Radio Shack or what's left of it) would be the "environmentally safe" solder such as is used for plumbing - but with the rosin core.
It works. I've used it. Not well. Not the most forgiving of solder or freely coating. You have to have everything PERFECT: clean copper, right temperature, even wipe the fingerprints off the solder as you use it. BETTER by a considerable margin is 60-40 rosin core solder - the old fashioned kind. It melts lower, is more forgiving of defects of application, coats your soldering iron better, and is generally easier to use. That said - lead/antimony solder will corrode in time. One of the defects of 1980s era calculators is that they were done with "dipped" technique using lead/antimony solder. Many of these calculators are now unusable because the solder connections have corroded and the connections don't work (or are physically "sensitive.") I miss my Texas Instruments SR50 calculator - the one with "Hyperbolic Arc-Sin" (the function that has no practical application in real life - but the calculator will tell you what the value is.) A solder joint is easy to renew in wiring work - not so easy for calculators. I have a roll (1 lb) of old fashioned "electronic grade" rosin core solder which I bought on Ebay for mid $20 - it can be found - at a price. This is my soldering "go-to" when it absolutely must be soldered correctly the first try - with no re-tries allowed. I can't think of a joint I have been disappointed with using this solder. The smell of using this even brings back memories of my Ham Radio experiences back in the vacuum tube age. Yunno - when you could find a power transformer in an old TV at the dump - and build a radio transmitter using it? Good luck. Several grades below Rocket Science this one. Although this may not be exactly true. Apollo 11 went to the moon on hand soldered connections. Joe in NH
Shudda kept the horse. Last edited by Joe K; 04-16-2020 at 08:46 AM. |
04-16-2020, 09:01 AM | #6 |
Re: Soldering
I always tin a wire with solder before I solder it to a component. This way you know it is clean enough to get a good stick. If you can't tin it then it's too dirty and needs cleaning. I only solder stuff when there is no other way. A soldered joint will work harden at the joint and the wire will eventually break if there is vibration or movement going on. I use crimps for as much as I can but they aren't like the ones you buy at the auto parts store and some are pretty expensive. |
04-16-2020, 09:24 AM | #7 |
Re: Soldering
Any electrical solder that has lead works best for me. Get something a bit bigger in diameter. The little stuff is difficult to work with in auto wiring. Make sure the connections are clean and bright. ALWAYS use flux. The old stuff that requires cleanup works, but the modern no-clean paste is really easy to use. Buy a good iron with adjustable temps. I do repairs on modern surface mount circuit boards under a microscope and the flux and lead solder have always worked for me.
04-16-2020, 04:21 PM | #8 |
Re: Soldering
Got it thanks
04-16-2020, 07:56 PM | #9 |
Re: Soldering
Soldering can be an art if you're so inclined. The key to soldering is to heat the surface you are soldering and let the solder flow onto, into, and around. Then look at it carefully and pull and poke to make sure you don't have what can be referred to as a cold solder joint. It isn't all that hard.
04-16-2020, 10:34 PM | #10 | |
Re: Soldering
04-16-2020, 10:42 PM | #11 |
Re: Soldering
I'll agree with almost everything said, but I always prefer the thin stuff takes less heat to melt it.
I was an AV tech for some time and worked on with circuitry for some time after that as well. Both only ever used Kester Rosin Core Solder. The radio shack stuff is useless in my opinion |
04-17-2020, 07:33 AM | #12 |
Re: Soldering
Lead and lead free have pros and cons. All of the information has been provided.
04-17-2020, 08:02 AM | #13 |
Re: Soldering
Higher lead content is easier to use. But it's poisonous, so don't eat too much of it.
04-17-2020, 08:15 AM | #14 |
Re: Soldering
04-17-2020, 08:31 AM | #15 | |
Re: Soldering
I recommend lead based solder because it's easier to get good results. I imagine most people here are not experienced at soldering so the lead based will give them the best results without a lot of experience. A couple of keys to success: Use electrical solder Have very clean surfaces to solder on Use a good flux (I like the new no clean gels in a tube) Apply heat to the part, not the solder Inspect for good joint and watch for cold solder joints Hope that helps! |
04-17-2020, 12:08 PM | #16 |
Re: Soldering
Since my soldering skills are pretty much non existent, I use aircraft grade crimpers.
04-18-2020, 09:50 AM | #17 |
Re: Soldering
63/37 solder is less prone to cold solder joints. When I worked for Motorola use of 60/40 voided the warranty. When soldering wires, make sure the solder wicks back into the wire, underneath the insulation. Also, use a big enough iron so you can heat the joint quickly, get the job done, and let it cool. Too small of an iron will actually end up with more heat damage. Use a brass brush on the soldering iron tip to keep the tip tinned with new solder. after a while the solder on the iron can become dead and that will lead to a poor connection. https://www.ebay.com/itm/63-37-Tin-L...8AAOSwi5VdyNhH
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool." Last edited by eagle; 04-18-2020 at 09:55 AM. |
