Old 04-25-2019, 01:04 PM   #1
rer_239
rer_239's Avatar
Default 29 roadster door handle
The driver's side door doesn't latch. There is one screw missing on the outside. How do I take the latch assembly out to check the handle threads?
Thanks
Dick
rer_239 is offline   Reply With Quote
Old 04-25-2019, 04:49 PM   #2
midgetracer
midgetracer's Avatar
Default Re: 29 roadster door handle
There are screws on the inside of the door under the upholstery panel.
midgetracer is offline   Reply With Quote
Old 04-25-2019, 11:55 PM   #3
mreman
mreman's Avatar
Question, do you use lock tight on the screws holding the screws in on the lock and hinges.
mreman is offline   Reply With Quote
Old 04-27-2019, 02:41 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Ford did not use a threadlocking compound (-Loctite) originally. No real need to do the same as long as the threads are good and the correct screws are used.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
