Old 04-09-2019, 02:34 PM   #1
Keith True
Keith True's Avatar
Default Stromberg 97
Is the center housing for a Stromberg 97 interchangeable with any other models? The carb guy I use just told me the threaded hole for the power valve has no threads left.I have a few flathead carbs,but no 97's.I do have a center marked,91-99,but I don't even know what it was from.It is in the bucket of flathead carbs I have.I'm not seeing many cores of them for sale right now either,A couple of people I've talked to tell me they may have them,but will take a couple of weeks for them to get them mailed out to me.
Old 04-09-2019, 02:47 PM   #2
tubman
tubman's Avatar
Default Re: Stromberg 97
Completely different animals. If it was me and everything else was in good shape, I'd clean everything up well and epoxy the power valve in.
Old 04-09-2019, 03:54 PM   #3
Charlie ny
20 years epoxy was the way to go, however I have found even the best epoxy (I've tried them all ) will desolve over time with todays leaded or unleaded gas. I have a good supply of 97 bowls, PM me if you are interested in a replacement bowl.
Charlie ny
Old 04-09-2019, 04:19 PM   #4
Brian
Brian's Avatar
Or...better still, get Charlie to build your carb instead of the guy you're currently using. You'll not be disappointed!
Old 04-09-2019, 04:38 PM   #5
Keith True
Keith True's Avatar
I've used this guy since the mid-70's,or at least his family.He is older than I am and I used to go to his dad.Hard to believe I have been going there for over 40 years now.I think he was a little surprised when he checked his old parts locker and didn't have the part.He always had lots of that stuff on hand,as he said,they were as common as dirt.He has saved some horrible,horrible things for me,some that looked like they had been soaked in salt water.
Old 04-09-2019, 05:11 PM   #6
Blastfromthepast
Try some JB Weld epoxy. Its like steel when its cured. It also can be drilled and tap threaded. Worked for me and will withstand the heat.
Blastfromthepast is offline   Reply With Quote
Old 04-09-2019, 06:41 PM   #7
tubman
tubman's Avatar
By "epoxy", I mean "JB Weld"; I've never had a problem with it dissolving in any kind of gas.
That being said, I'd go with "Charlie ny". He has the parts, and his workmanship is first class. There are none better. When you have the chance, do it right.
Old 04-09-2019, 06:42 PM   #8
uncle max
uncle max's Avatar
Originally Posted by tubman View Post
By "epoxy", I mean "JB Weld"; I've never had a problem with it dissolving in any kind of gas. Give it time!
Charlie knows.
RIP Tyler... My Son, Helper & Best Friend.
Feb '78 to Father's Day '10.
www.97-express.com ~ [email protected]
uncle max is offline   Reply With Quote
Old 04-09-2019, 07:13 PM   #9
tubman
tubman's Avatar
Also, Max knows.
Old 04-09-2019, 07:31 PM   #10
flatjack9
flatjack9's Avatar
I would surely trust Charlie.
Old 04-10-2019, 03:22 PM   #11
Terry,OH
Terry,OH's Avatar
The 91-99 is a Holley body for a 94 Carb from 1939-41 Ford Good find look for the top and the bottom.
Old 04-10-2019, 03:56 PM   #12
Keith True
Keith True's Avatar
I just found a whole one of those 91-99 carbs.it was in a box that the mice had set up housekeeping in.Rusted the linkages almost off.Insides are like new.Also found a few later carbs marked 8BA.The carb guy wants those for cores.
Old 04-11-2019, 10:23 AM   #13
Charlie ny
Keith,
The bowl is on the way......due Sat 4/13 !
Charlie ny
