Old 09-25-2017, 06:36 PM   #1
jacob smith
jacob smith's Avatar
Default 36 ford wiper motor
I have a 36 Ford convertible with the hart shaped wiper motor does anyone have a photo or diagram on all the parts to install in the windshield frame
Ford
jacob smith is offline   Reply With Quote
Old 09-25-2017, 07:19 PM   #2
Don Rogers
Don Rogers's Avatar
Default Re: 36 ford wiper motor
conv sedan/cabriolet or roadster/phaeton??????
Don Rogers is offline   Reply With Quote
Old 09-25-2017, 08:44 PM   #3
jacob smith
Conv sedan
Ford
Old 09-26-2017, 08:41 AM   #4
Kerk
I have one I was going to take to Hershey BUT health issues have forced me to change plans. My space at Light 84 will be MT.
Kerk is offline   Reply With Quote
Old 09-27-2017, 04:09 PM   #5
Mike in AZ
Mike in AZ's Avatar
Jacob, has Al Casteen been in touch with you about your C/S??
Mike in AZ is offline   Reply With Quote
Old 09-27-2017, 05:20 PM   #6
jacob smith
Mike no he has not.
Ford
Old 09-27-2017, 05:40 PM   #7
Terry,OH
Terry,OH's Avatar
From the hardware book it appears the same hardware as the Cabriolet. Special nut for the shaft, flat washer, Grommet 48-761370 (flat rubber or leather same OD as washer and same ID as the shaft) On the interior is the spacer 48-761424. I believe that is all.
File Type: jpg 35 Cabriolet wiper motor spacer dimensions.jpg (13.2 KB, 21 views)
Old 09-28-2017, 08:04 PM   #8
jacob smith
Terry would you know were to get one? And how is it installed
Ford
Old 09-29-2017, 06:16 AM   #9
Terry,OH
Terry,OH's Avatar
Ford used the spacer with different lengths and finish on a number of cars. If you can find a longer one you can whittle it down to the correct length and have it chromed. It is made of white metal. The wiper shaft slides through the hole in the center and the step goes against the motor and holds it in place without any attachment hardware. The two small tits on the other end go against the wind shield frame. The one stem nut (5/16-32 with 7/16 hex) holds the assembly together. I believe Kent Jaquith at "Clean Sweep" has the spacer
Kent Jaquith
Clean-Sweep
2633 SW Obsidian # 15
Redmond, Oregon
(541) 923-4319
Old 09-30-2017, 08:39 PM   #10
jacob smith
Thank you Terry. I checked with Kent and he is out right know. I am going to Hershey next week maybe I will get lucky
Ford
