09-29-2015, 03:10 PM | #21 |
Re: Engine knocking
Hi
Will check the timinggear. I can remove the gearcover from below. Can I replace the timinggear without taking the engine out? Do I need a special puller or will it slide out? Can someone help me with a link to the right part and maybe a link to a good guide. It's a stock 1935 221 cui flathead in a model 48. Thank you a lot:-) Last edited by TDS; 09-29-2015 at 03:16 PM. |
10-02-2015, 05:54 AM | #22 |
Re: Engine knocking
Hi any update on this problem ?
10-02-2015, 09:40 AM | #23 |
Re: Engine knocking
"Exactly the same rythmn every time"
If the frequency of the rythmn doesn't increase with the rpm its not internal to the engine. Any internal engine knock will increase its frequency with higher rpm.
Nomad |
10-02-2015, 02:25 PM | #24 |
Re: Engine knocking
[QUOTE=Lanny;1163695]================================================== =
There are some of the most quallified flathead mechanics in the world on this site, and some damn good back-yard mechanics here, too. The information is free for the asking, and more times than not, the advice given here helps the original poster with his problem. .[/QUOTE I know there are a lot of qualified flathead folks here and I regularly use this site for good information, but using a qualified mechanic is just another option and doesn't that qualify as another opinion? My intent wasn't to say these other opinions don't count for value, just another option is to use a mechanic. Sorry if any one with common sense was offended. My 2 cents!
"DON'T CRUSH IT....RESTORE IT" |
10-03-2015, 02:08 AM | #25 |
Re: Engine knocking
Hi
Work has kept me busy so I havnt had time to get further into it The frequency of the rythmn does increase with the rpm comes up. Hope to find time to take the timing cover of today. Will post update later |
10-03-2015, 09:18 AM | #26 |
Re: Engine knocking
The noise on mine would change when I pushed in on the clutch. |
10-04-2015, 08:26 AM | #27 |
Re: Engine knocking
Hi
Finally got to it... Camgear og crankshaftgear looks just fine. Teeth are all there. Timing marks are right on. Messure endplay on camshaft to 0,55 mm (around 0,216 ") + gasket. Messured with a feelerblade between camshaft end and back of timingcover. I took this video before I took it apart. Fan belt is of. Still this knocking rythm. Gets louder when under load. I can feel the knocking on the distributor body. https://www.youtube.com/watch?v=BJCx...ature=youtu.be Please see photos... Im stuck any good ideas ? Last edited by TDS; 10-04-2015 at 08:50 AM. |
10-04-2015, 10:12 AM | #28 |
Re: Engine knocking
I'd bank on what Walt D. has to say.
He's helped me in the past. Just listening to the problem my engine was having he gave a diagnosis of the fix. He was dead on. This site is better than bringing ur car to a mechanic. The best mechanics for the flat head in the world are on here and want to help. |
10-04-2015, 11:50 AM | #29 |
Re: Engine knocking
Manifold of.
Turned the crankshaft with a wrench. Valves opens and close freely. Some sludge down at the valvetrain. Cleaned it before picture taken. I might hear a one knock when turning the crankshaft a full 360 degrees but its hard to say if its just the old chassis. Is the camshaft and the crankshaft connected beside the camgear? Was pretty sure I would find a damaged camgear or crankshaft gear but they look fine? Last edited by TDS; 10-04-2015 at 11:54 AM. Reason: detail |
10-04-2015, 03:30 PM | #30 |
Re: Engine knocking
Did you try shorting the sparking plugs?
Martin. |
10-05-2015, 04:43 AM | #31 |
Re: Engine knocking
you say it started after you changed the carb . are you sure you did not drop something in the manfold . also check the carb for missing parts . remove spark plugs check them to see if something is hiting the plug.
10-05-2015, 06:32 AM | #32 |
Re: Engine knocking
The vacuum brake on the distributor !!! ..Maybe working differently because of different carb/conection? or vacuum taken from different port...or may simply be that the vacuum brake has been stuck in the past and has now moved and or freed up , causing the advance plate to move and cause a knock.. Not an ignition knock , but a mechanical knock in the distributor.
Did you try taking the carb back off and putting the original one on. |
10-05-2015, 06:59 AM | #33 |
Re: Engine knocking
Hi Everyone, It's a little late for this suggestion, but TDS can you try a different distributor? You've said a couple of times that you can feel it vibrating.
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
10-05-2015, 01:46 PM | #34 |
Re: Engine knocking
Hi
It started when I had another distributor installed. I replaced it with a rebuild distributor, I rebuild it myself. I thought it was an issue with the plunger and maybe incorrect timing. Replace didnt change anything. Tried to disconnect one sparkplug at the time but it didnt change anything. The knocking is clearly at the front of the engine. I dont think a bearing will that kind of knocking neither at the camshaft or the crankshaft. But maybe Im wrong?.. Going this far I should proberly take of the heads of too. Can I pull the camshaft out without removing the valves?. Is there other issues I need to be aware of if I pull the camshaft out?. Thanks.. Last edited by TDS; 10-05-2015 at 02:00 PM. |
10-05-2015, 02:09 PM | #35 |
Re: Engine knocking
No, you cannot remove the cam without removing all the valves.
I'm following this with interest because I too have something similar. I have had my heads off twice, replaced the valves, guides and followers etc, had the distributer off (which is a Bubba rebuild), had the cam gear cover off, replaced #5 piston and rings and bearings, and still that persistent knock. Have you used a stethoscope (fancy name for a length of rubber hose) to try and isolate the knock? I did, and the #5 valve area is very noisy compared to other cylinders, but I can't trace the knock. Maybe you will have better luck than me. Last edited by Bassman/NZ; 10-05-2015 at 02:17 PM. |
10-05-2015, 04:01 PM | #36 |
Re: Engine knocking
your first post said after you chaned the carb now you say after you changed the dist. which is it
10-05-2015, 04:46 PM | #37 |
Re: Engine knocking
Could it be piston slap?
10-05-2015, 06:42 PM | #38 | |
Re: Engine knocking
10-06-2015, 09:21 AM | #39 |
Re: Engine knocking
I think you have something in a cylinder or rod bearing.
10-06-2015, 10:52 AM | #40 |
Re: Engine knocking
Check the carb and see if all 4 of the brass screws that hold the butterflies in are there. I was sure I had a rod bearing go and it was one of those screws came out and got into a cylinder.
