06-06-2015, 11:11 AM | #1 |
Another U Joint question
Hi Guys,
Could anyone pse ID the U joint, in the attached pictures, which I found slap in the middle of my Pickup. Regards Chris |
06-06-2015, 11:31 AM | #2 |
Re: Another U Joint question
what pictures??
Mark Maron Ill., Region MARC & MAFCA MARC JSC Member MAFFI Trustee National Facebook Admin. https://www.facebook.com/groups/MARC.group/ A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
06-06-2015, 01:06 PM | #3 |
Sorry,
06-06-2015, 01:07 PM | #4 |
One more,
06-06-2015, 02:29 PM | #5 |
Model A.
06-06-2015, 10:19 PM | #6 |
Regards Chris |
06-06-2015, 11:16 PM | #7 |
The vendors sell a more modern ford U-joint used thru 1948, the one you show was factory for the model A. You could be driving an early car what is the serial #?
06-06-2015, 11:58 PM | #8 |
Pedal shafts were made one inch for the RH drive cars and 3/4 for LH don't know why. I made mine from 1 inch stock and used big end (wrist pin) bushes
Ahooga, Rosco. |
06-07-2015, 02:11 AM | #9 |
Tks J,
I believe mine was built from parts and I do not have the serial number because I never saw the frame and it might not even have the same engine number. But thanks anyway. The engine is at the engineering works at the moment. Regards TKS Roscoe, Funny enough the LH/ RHD came to mind but I thought NAA NEVER, CANT BE. Thanks for the tip. Regards Chris Cape Town |
06-07-2015, 03:22 AM | #10 |
Les Pearson has written a book on the right hand drive model A , he used to manufacture most of the parts, but has sold the business now and retired to write about Model As.
Selling his book on Trademe ( a local version of Ebay) http://www.trademe.co.nz/Browse/List...x?id=897509976 also available from Amazon and Model A dealers or you can see his book and his contact details on Youtube https://www.youtube.com/watch?v=CRFtCeGXwOw He has written other books too. He sold the parts business to these guys. http://www.earlyfordparts.co.nz http://www.earlyfordparts.co.nz/right_hand_drive.htm |
06-07-2015, 04:52 AM | #11 |
Tks for the heads up, Leakers, I'll have a look.
Chris |
06-07-2015, 11:35 AM | #12 |
Forever 4,
Please read my post #6 then you will know what the 'spam' is all about |
06-08-2015, 07:15 PM | #13 |
It seems as if U joints have been out of stock for more than a year now. Any one know of a vender that might have, please. Or suggestions for a substitute unit.
Regards Chris |
06-08-2015, 08:22 PM | #14 |
Some are listed on Ford barn swap section. What is wrong with the one you have?
06-09-2015, 12:01 AM | #15 | |
I have nothing to do with Mr Pearson other than that I have purchased parts from him. My intention was simply to share information, just as your website does sir. May I ask, Why do you list your website at the bottom of every post you make? |
06-09-2015, 12:56 AM | #16 |
J,
Mine still seems good and solid BUT the front part is cracked. It looks as if there is a washer between the gearbox output shaft and the front section of the U Joint which was not insetred correctly. I think the washer was sitting at an angle when the bolt was thightened, which caused the housing to crack. Apparently the vendors hadnt had any for a year. I suppose it could be welded up until I can get a new one. It is such a hugh job to replace it at a later stage, so I was hoping there was a later model I could use. Regards Chris Edited. In fact if you look closely at my first picture the one in post #3 you can see the crack where the through bolt tightens down. Last edited by Floats; 06-09-2015 at 01:04 AM. Reason: More info provided |
06-09-2015, 01:16 AM | #17 |
06-09-2015, 02:13 AM | #18 |
Hey Tom, you are correct. I thought it was part of the casting. I pried it off and the U joint is fine but the washer is cracked.
Thank you very much Tom. I am good to go. And thanks every one for your input. Regards Happy Chris Cape Town Last edited by Floats; 06-21-2015 at 05:12 AM. |
06-09-2015, 05:20 AM | #19 |
That's a special thick washer with a tab to fit between the splines.
Do you have a spare, or can you order one? |
