Old 04-12-2021, 07:26 PM   #1
melisahe
melisahe's Avatar
Default 1949 ford f1 with h6 and t5
Rebuilding a 49 f1. I bought a rebuilt 6 cyl with a t5. Can't get the clutch to work right. Have a pull slave cylinder from speedway that seems to have air in it that I can't get out. Bench bled numerous times. Can't get more that an 1/2 inch throw in the truck. Get two inches on the bench. Any thoughts on how to get it to work properly. Maybe a different slave cyl.? All help apriciated. Tks Mike
melisahe is offline   Reply With Quote
Old 04-12-2021, 07:33 PM   #2
Ross F-1
Ross F-1's Avatar
Default Re: 1949 ford f1 with h6 and t5
What are the diameters of the master and slave?
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-12-2021, 11:44 PM   #3
Aarongriffey
Good point that Ross brings up.
First I would open (loosen) the line where it goes into the master cylinder and slowly push the pedal down.
Let it up slowly after tightening the line.
If that doesn’t, get a helper to pump it really fast and hold it down while you loosen the line at the master cylinder.
Aarongriffey is offline   Reply With Quote
Old 04-13-2021, 07:24 AM   #4
skidmarks
skidmarks's Avatar
Which T5 and bellhousing?
skidmarks is offline   Reply With Quote
